I forget how to check (measure) what my bolt pattern is for my '82 250r Atc (rear)
Is it 4x110? Its for my son's new Atc :-D
1982 Honda Atc 250r - Daughter's
1982 Honda Atc 250r - Son's
http://forums.atvconnection.com/photos.cfm/ID/1566/#TOP
4 on 130
__________________
'85 ATC250R
.030 Over Wiseco
FMF Pipe/Answer silencer
36PJ Keihin
K&N
Boyesen reeds
Magura hydraulic clutch
Roost Boost
MSR bars
OMF swingarm skid
ITP Beadlocks
Three Wheelin' Since '84
Thanks. I think that was the only year for that bolt pattern.
Thanks again
To make sure the hub wasn't changed. How do I measure it?
Measure from center to center of two studs accross from each other. My tecate is 6 1/8" from center to center and that is 156 millimeters. So mine are 4 x 156 Convert the inches into millimeters.
Someone changed the hubs!
I measured it @ 4.5" and this chart shows it to be 114 which I assume is a 110 or 115 bolt pattern?
http://www.hawkmicro.com/convert/Convert_HawkMicro.htm
If you are measuring correctly, across the center of the rim, using the center of the holes as the reference points, you have Banshee hubs and they 4/115.
Thank you :-D
They look different than my daughter hubs which are 4/130 (stock)
