WHat is the biggest cc you can bore a 350x. Theres a flat track blaster that races here w/ a 350x motor in it.Someone said it was a 385X,,,is this possible?? This blaster hauls major Arse. He is in a different class so i havent raced against him.
I think Powroll used to go up to something around 390-400. Don't know if they still make anything that big.
Lots O Trikes!!!!!
i think the biggest kit powroll has is 430.
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
If you want to go bigger than 430 you can talk to LA Sleeve, they make a kit for the 350x. The sleeve and piston that comes with it makes the 350x to a total of 452cc!
3WheelsForever / Virgil
TrikeFest 03, 04, 05, 06, 07
1985 Honda ATC350X - TF2015 Project
YZ426 Hybrid Trike - On the back burner
I bet that costs a pretty penny :shock: .
"I am going out of this world.....the same way I came in...screaming and covered in blood."
LOL I seen a 460!!! yes 460 kit on ebay a while back.It went for over $700 :-D
1969 Trail 70
1973 ATC 70
1983 ATC 70
1986 ATC350X
1986 ATC250R X 3
1986 ATC200X
1987 ATC200X
2012 Polaris RZR
with machine work to the lower cases ( for sleeve clearance) a 350X can be built up to 500cc. the crank is more then capable to withstand the added displacement.
WTF,,,blink blink,are my eyes fooling me. Should i say welcome back Mr Atc...... :shock:Originally Posted by MR ATC
R.I.P Raven
2006 Yamaha Banshee Special Edition
1996 Honda CBR 600 F3
Here's a thread that say's TC Racing makes 350X engines all the way up to 550's converted by him..$$$$$$ but very fast.
Link=> http://forums.atvconnection.com/messageview.cfm/catid/15/threadid/362144.cfm
550?!?!?!? Hayseuss! That thing would fly!!
1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
1984 Honda 200ES
198? Yamaha YT60 Tri-Zinger
TrikeFest '04 & '07 Survivor
From my information, max overbore on a 350x is 1mm which would be 359cc. So in answer to your question, you cannot bore a 350x out to a 385, however several big bore kits were offered for it at one time, and he had to have installed one if his 385 is accurrate.
Thanx for the info.I'm not to familiar with 350x motors and big bore kits.
There are lots of answers and some seem to be contradictory.
To clarify, there are different ways of increasing the bore on an engine.
I don't know the 350X in particular, but I know engine modification in general. One person mentioned that max overbore is 1mm, which is a total of 359cc. This would be the maximum overbore on the STOCK cylinder sleeve.
If you want to go beyond 359cc, you would need to install a new sleeve. This isn't terribly difficult. You bring it to a shop, and they press out the old sleeve, bore the cylinder a little, and press in a new sleeve. This will probably get you up to about 400cc.
To go bigger, you need an even BIGGER sleeve. This gets difficult, because the bottom end can only accept a certain size. So, in order to go bigger, you need to press a bigger sleeve into the cylinder, and ALSO you need to machine the cases on the bottom end to accept the bigger sleeve. This is no small task. If you send it to a shop, it is usually at least $500 in labor just to split the cases to machine them. However, with this method, you can increase the bore to over 500cc.
