Results 1 to 7 of 7
Thread: Any one make a custom resivor mount 250r
    rustyhondas's Avatar
    rustyhondas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Missouri
    319
    Is there anything slick that mounts the resivor outside of the frame ?Click image for larger version.
    86 atc 250r
    85 atc 70
    84 atc 200s
    05 650 rincon
    06 400at rancher
    93 lt80
    02 kx65
    Nov 2006
    Missouri
    319
    Got it ,two adel clamps and two homemade straps
    Sweet ,it's got nos bro
    86 atc 250r
    85 atc 70
    84 atc 200s
    05 650 rincon
    06 400at rancher
    93 lt80
    02 kx65
    Mexico
    9,019
    Nice! I just noticed that my Works rubber mounts crumbled to pieces after sitting in the shop for a few years I need something less crappy as well. Yours look great!
    Nov 2006
    Missouri
    319
    Thanks , after I started playing with the trx shock
    I figured I screwed up . Now it's totally liget .
    Absolutely a viable swap
    Upper banjo doesn't hit the air box connector,the hose isn't going to hurt anything and is above the chains path.no big deal
    86 atc 250r
    85 atc 70
    84 atc 200s
    05 650 rincon
    06 400at rancher
    93 lt80
    02 kx65
    Williamstown PA
    5,825
    SRS on ebay sells bottle mounts, or you can use 83-84 250R oem rubbers on. I have one on my 200x with 250R shocks.
    Mexico
    9,019
    Do you have a link? I can't get it to pull up on eBay.
    Sep 2011
    Ocean Beach, CA
    1,333
    use 350X oem rear shock reservoir mounts. rubbers go around the resi and between the resi and frame. clamps fit perfect. i used the 350x mounts to mount the 250r resi on the 500 build
