Thread: tri z shift fork placement
    bushwacker51 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Cherokee, Oklahoma
    267
    I split the cases on my 1985 yamaha tri z and was wanting to make sure I got the two shift forks that are on the one shat in the correct order. There is no mention in the manual which one goes on first I think I have it right just want to make sure any help would be appriciated thanks Glenn O.
    jonolanracin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2006
    west tenn
    319
    The numbers on each fork face the case
    Mexico
    9,018
    I don't recall exactly how they are identified, but I recall the are not the same and I doubt they can be mixed up and still fit, or I'd have put mine in wrong. Did you try putting them in both ways? That would answer your question.
    Jun 2003
    Cherokee, Oklahoma
    267
    Okay ill check out the numbers thanks
    Jul 2012
    Seattle, Washington
    1,543
    Yea it only works one way, I reassembled my tri z engine myself it was easy. If you get it wrong the fork will stick, it only works one way.
    http://www.3wheelerworld.com/album.p...id=2522&page=4
    Jul 2012
    Seattle, Washington
    1,543
    Here's the part numbers for the shift forks: http://www.cheapcycleparts.com/oempa...shift-cam-fork
