Results 1 to 15 of 15
Thread: need some help
    Apr 2015
    Colorado Springs, CO
    8
    need some help
    I'm looking to see if there is anyone in Colorado Springs that can help me out with my 83' Honda ATC 200x. I've been messing with this thing for years.
    Oct 2015
    MD
    13
    Whats the problem?
    Apr 2015
    8
    Well when i push the throttle it dies. Also sounds like a ticking noise in the top end.
    Feb 2016
    crivitz wi
    11
    Quick guess but not getting enough gas. Try cleaning the carb. And the noise could be the valves out of adjustment. Get a manual and follow the troubleshooting guides
    Apr 2015
    8
    Already had the carb cleaned. I have a manual so ill look into the vale adjustment
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by Sloth21 View Post
    Is it worse when the engine is cold or hot?
    Post a photo of your spark plug.
    Nearly white porcelain is lean.
    Black dry porcelain is rich.
    Lite tan is happy.
    Try it with the choke half on then full on.
    Try it with the air box lid off.
    Try it with the air filter removed.
    Try it with the clip on the needle raised to the top of the needle.
    Slidell, LA
    4,738
    A cleaning won't cut it likely. You need to rebuild the carb. The ticking noise is either valves, improper cam chain tensioner adjustment or con rod bearing going bad.
    gimmeamidget is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    utah
    436
    Will it rev up with the choke on?
    Apr 2015
    8
    I can get it too start with choke up. But it's a pain to start. Cleaned carb and had it rebuilt already.
    Like I said at the beginning, it'd be easier if someone was in the same town. Cause non of this is helping at all
    Feb 2016
    crivitz wi
    11
    If it's any help, amazon has carbs brand new for around $20. With mine I figured for the price it was an easy choice to just replace the whole thing. Then go from there.
    Apr 2015
    8
    ok. I might do that. I already had it rebuilt
    Apr 2015
    8
    Here's a photo of the plug
    Slidell, LA
    4,738
    Your plug indicates a Rich condition. What size pilot and main jet are you running?
    2,591
    Also list what exhaust and intake mods have been made to it.
    Apr 2015
    8
    110 for the main jet. Not sure about pilot. Whatever came in the repair kit is what im useing
