I have a 1982 Honda 185s that I have been slowly fixing up and getting close to finished (I hope). The most recent change is with the rear tires and rims which I took apart, stripped off the paint down to bare metal, then primered and repainted using engine paint. I previously replaced the front tire and rim (1-piece so no seal worries), so this is only about the rear.
My question is about the joining of the 2-piece rim. I have had several people recommend using a thick bead of the blue RTV to seal it up, which is what I did, but I'm wondering if anyone else has done this or had a better solution. There is no gasket other than the RTV now. Since I just finished this about an hour ago, I have to wait 23 hours more before trying to seat the bead on the new tires. Does the RTV work and hold up well? Is there a better way you have found to do this?
