Results 1 to 13 of 13
Thread: 1982 Honda 185s 2-piece wheel question
    Jan 2016
    Hesperia, CA
    7
    I have a 1982 Honda 185s that I have been slowly fixing up and getting close to finished (I hope). The most recent change is with the rear tires and rims which I took apart, stripped off the paint down to bare metal, then primered and repainted using engine paint. I previously replaced the front tire and rim (1-piece so no seal worries), so this is only about the rear.
    My question is about the joining of the 2-piece rim. I have had several people recommend using a thick bead of the blue RTV to seal it up, which is what I did, but I'm wondering if anyone else has done this or had a better solution. There is no gasket other than the RTV now. Since I just finished this about an hour ago, I have to wait 23 hours more before trying to seat the bead on the new tires. Does the RTV work and hold up well? Is there a better way you have found to do this?
Name:	Jeff's 1982 Honda 185s - 2011 - 1.JPG
ID:	228323   Click image for larger version.
Name:	185s Rear Rim - Before.jpg
ID:	228324   Click image for larger version.
Name:	185s Rear Rim - After.jpg
    1985 Honda 200X
    1982 Honda 185s
    Nov 2015
    hudsonville mi
    65
    There's rubber seals that are suposed to go in between them.Click image for larger version.
    Jan 2016
    Hesperia, CA
    7
    The ones that were on it crumbled when I took the rim apart. I was advised to use the RTV instead of replacing the seal and told that the seals never work well once taken apart. Just wondering if anyone else has done this and how well it works.
    1985 Honda 200X
    1982 Honda 185s
    Feb 2016
    Georgia
    66
    RTV will work just fine. Really no reason you need to wait that long. 24hrs is for full cure. After about 2 you are good to seat the beads in my opinion.
    Jan 2016
    Hesperia, CA
    7
    Thank you, I've been a bit nervous about it. Would really hate to have to scrape it off and probably have to re-primer the area.
    1985 Honda 200X
    1982 Honda 185s
    Jan 2014
    La
    1,062
    In my experience with two piece rims as long as you clean around the sealing place those seals last a long time and are very reliable.
    Dec 2012
    Sterling Heights MI
    4
    Ive always Just replace the O-Ring using a thin film of grease. Silicone will work in a pinch, or if the rim gets bent keeping the O-ring from working.
    ATC 250R I Live to Ride and Slide to live Rad Rod Shed Holiday Honda 3 Wheel Racing Team #8
    San Marcos Ca.
    715
    I always use the O-rings with a little Gasgacinch .You can put air in the tire to bead them up rite-way.I use this stuff all the time with no problems.
    * 1970 US90 Red
    * 1985 ATC 200s
    Jan 2016
    Hesperia, CA
    7
    Ran into a bit of a glitch...I waited the full 24-hours for full cure of the blue RTV and seated the bead on one of the rims. The problem is that for some reason the RTV didn't dry at all, it came out around the stud holes and was as wet as when I first applied it. The current plan is to let them sit a few days and see if that helps, but not sure why it didn't cure, humidity is at 4% here.
    1985 Honda 200X
    1982 Honda 185s
    Mar 2016
    NorthwestGermany
    35
    Can only tell you my experience with the rtv stuff that is sold here in europe:
    Avoid the blue stuff!Its only for that very modern engines to smear that rubber gaskets a bit.So more or less for engines that dont really need silicone from the factory..
    That blue stuff will always stay jammy.I have seen this polluting the oil on old carb engines a hunnert times,but thats another story.
    Best stuff you can get is the red "gasket maker",thats what i use for 30years now.
    Its from stateside by the way,so should be easy to get for you.
    The red stuff will turn into rubber in no time,its awesome.I use it on intake manifolds,waterpumps and so on.Where there is more pressure then on our 3wheeler tires.Never had a single problem.
    Dont worry,not your fault.the blue stuff sucks..
    Ollie
    Feb 2016
    crivitz wi
    11
    I too have used the red gasket maker on many things. Works wonders for sealing just about anything.
    sanchez's Avatar
    sanchez is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    where ever i may roam
    228
    Buy a replacement o ring (hydrolic shop ect) and a little slime. Or tube it yo!!!
    Appearing since '07
    Looking for a place to happen...
    Making stops, along the way
    Jan 2016
    Hesperia, CA
    7
    The Red RTV worked perfectly! I'll never buy that blue garbage again. Thanks for the advice!
    1985 Honda 200X
    1982 Honda 185s
