Thread: A question
    Surprise, Az
    10
    A question
    In the 200x trans, is the bearing that sits on the final drive supposed to be pressed on?
    Surprise, Az
    10
    On the out put shaft
    Slidell, LA
    4,738
    I am assuming first gen. If so then all the tranny hearings are pressed into the cases.
    Surprise, Az
    10
    The output shaft, thats on the other side of the chain. When u split the cases. It doesn't pressing the case, not on mine anyways. It's an 83 200
    Surprise, Az
    10
    Can do all my own blasting and polishing, thanks tho
    Surprise, Az
    10
    When I figure out how to post pics I'll submit my 185 autoc conversion, and how I followed the posts on how to shark tooth my 200x kicker gears
