looks like mair, oem have raised lettering behind seat area
Do you have any other pics of them. They could be oem 85 250r fenders .
250r rules
Any pics from the bottom? Easiest way to tell
"I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
Look like maier to me..
1978 ATC70 w/ Piranha 140cc
2017 YZ 250x- Braap
Maier all day everyday. Run it, ride it. OEM is pointless unless you have a mint set on something your not going to ride.
looks like a vintage set of Maier fenders to me. the dull red gves them away.
Yeah turns out they are definately old school maier. Still a decent set but only wanted them if they were OEM, as I don't have a 250r at the moment. Thanks for your help.
Matt
1980 ATC 70 Needs Restoration
1985 ATC 250es Fully Refurbed
1986 ATC 350x Mint Original
Not all the oems have the raised lettering. I have a set that has them and a set that doesn't. The sure fire way to tell is look at the underside. The oems were injection molded so they will have a number witness marks made by the ejector pins in the mold. I've never counted them but there is more than a few, some will be round about 5/16 diameter and some will be elliptical shaped. Kinda uniform spacing from one side to the other. Sometimes the elliptical ones will have some grooves across them.
YAMAHA 450 HYBRID
85 350X- RED
85 350x -BLACK
86 350x-WHITE (with Goki)
85 250r
83 atc 70
84 atc 70
84 atc 110
09 yfz 450
2006 Arctic Cat Prowler
RZR XP 900
Thanks for that Bob, will be good to know for future. I wonder why Maier doesn't use the injection mould setup in the manufacture of their fenders.
Matt
An injection mold that size would probably be around $500,000 to build, weigh around 7 or 8 tons and have to be run in a very large molding press costing another half a million dollars. It's a very expensive process designed to produce tens of millions of parts.
YAMAHA 450 HYBRID
85 350X- RED
85 350x -BLACK
85 250r
83 atc 70
84 atc 70
84 atc 110
09 yfz 450
RZR XP 900
Makes sense. Keep costs low so us battlers can afford them I guess. Cheers. Can't beat that OEM look though can you!
Matt
