Thread: 1985 200X rear shock rebuild question
    Mackus84's Avatar
    Mackus84 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2016
    Lakeland, Fl
    427
    Ok so im in the middle of a resto/mod on an 85 200x. Time to rebuild the shock. Im doing all work myself except the stuff i cant do. So i have the entire shock, and nitrogen canister apart per the service manual instructions. The canister had very little pressure when i depressed the valve stem. That means it has all leaked out right? Or does it just happen, as in depressurizes over 30 years? Im assuming the former, and that it has leaked out. With that being said, that means the shock needs new seals and what not, but the manual states to just replace it. Is there not a way to replace the seals? Ive only been able to find one rebuild kit for the rear. Which seems odd to me since most parts are plentiful. Does this look like what i need to rebuild it, or no?Click image for larger version.
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    Btw, it did still have fluid in the damper, just no pressure in the nitrogen canister
    Jan 2014
    La
    1,062
    It probably just depressurized over time if there was no fluid leaking out of the shock. Dump all the old fluid out and replace the seals and replace the fluid with automatic transmission fluid. Now you could have a hard time finding someone to fill your nitrogen cartridge back up. I know it took hours of calling every contact and motorcycle, atv shop in town until I found someone who could fill the shock.
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    Ok. Ill get all that done. And yeah i called a few dealerships around town to see if they could fill it, and they couldnt but they referred me to a motorcycle suspension place like 5 minutes from my house so i got that covered
    Sep 2015
    US
    6
    Niice! If you get this kit and do the rebuild yourself, I'd really like to see how the job goes. Please post pics as you dig into your shock. Thanks in advance!
