Results 1 to 11 of 11
Thread: Removing spray paint from plastic?
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    I was wondering on how to go abouts removing spray paint(black) from yellow plastic? If anyone has info or can help me out,please post and let me know. Thanks in advance!
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
    Front royal, va
    2,186
    try "airplane paint stripper" from wal-mart
    Watertown, New York 13601
    3,382
    You have to watch that paint stripper It likes to melt plastic.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    renotrikeguy's Avatar
    renotrikeguy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Reno,Nevada
    433
    Graphity? remover works real good to. You put it on like car wax and wait a bit then rub it and the spray paint off.
    Chris (Reno,Nevada.)
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    85 Honda 250es BigRed
    99 Honda XR250R
    04 Honda CRF150F - Cousins Ride
    Aug 2002
    Creswell, OR
    889
    MEK, Methyl Eythel ketone.
    However if there were scratches your gonna have a bugger of a time getting it all off.
    If its real brittle paint try using a rubber mallet. a couple good wacks and the stuff with just cracks off. I had a tecate fender I did that to after messing with it for an hour.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    atckowalski is offline Formerly "aaakowalski" Arm chair racerJust too addicted
    Nov 2002
    Northern Mi.
    516
    Try taking razor blades to it.I know that sounds weird but it works. It just takes awhile but is 10 times as fast as sanding. The only thing is, the blades can get dull very fast, so if you don't notice, it can get tetious, but make sure you get the kind of blades with 90 degree ends on them or you can't get the corners very easily.
    Houston,Texas
    1,044
    I use a mouse sander, and plastic renew so it isn't all dull. The electric sander works wonders on the rides around here,because the people I bought them from liked to spray paint,ALOT .
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Dec 2002
    749
    If you go to Napa they have some Water Rinsable Paint Stripper. This is what a friend and I used on some 400ex fenders. Takes a while to get it all off but it doesnt hurt the plastic like other paint strippers.
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    620
    Brake fluid will take it off without harming the plastic. I've never done it myself, so I don't know how fast it works. You could try a small spot to see if it's feasible.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Rittman, Ohio
    6,276
    The paint stripper from KMart works well, especially if followed by a pressure washer. When my TRX250 was stolen I had the pleasure of removing all the paint the jerks used on it. Be aware too, though, that stuff takes vinyl decals and stickers right off!
    Ive used 3 different kinds of it, and never had a problem with it attacking the plastic, and I left it on a long time before spraying it off.
