Thread: Need Help, 84 200 ES big red not starting from switch
    wellys88 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2015
    WA
    194
    it starts when i cross the solenoid, nothing happens when i cross the switch, both jumper wires Are live on solenoid when i turn on ignition, if I cross the solenoid it starts right up, if i just put 12 volts with multimeter to starter side of solenoid it shorts out,
    Nov 2015
    WA
    194
    Changed out solenoid, still doing same
    Nov 2015
    WA
    194
    took batery out and charged it, when i put it back in, when i hooked up solenoid cable, it spun the starter and wouldnt stop, guess i need to get into the harness and find out whats shorting out, all conections look good and have continuity at both sides, oh and it only started happening after I flipped it down a hill about 10 times
    ericmreimer's Avatar
    ericmreimer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Splendora, TX
    296
    Do you have the wiring diagram? sounds like you might just have a loose or disconnected wire somewhere. i know you said you checked continuity but if you dont understand the harness and how its circuited, its tough to really track down issues like this.
    sounds like an issue somewhere in the starting circuit but i think you knew that lol. i'll dig out my diagram.
    1984 Honda ATC200ES saved
    Project in progress 1984 ATC200ES with Trx200 rear suspension/200m front suspension
