Results 16 to 30 of 49
Thread: John Deere garden tractor attachments
    Aug 2015
    Idaho
    847
    ^^^^Nice job, Dirtweed! Looks like new. Maybe better.?
    House Springs MO
    5,496
    I know nothing about these older JD lawn tractors except for the fact I want one really bad. There is a guy close to me who has a clean 214 for $500. Everything but the variable speed control works.
    Aug 2015
    Idaho
    847
    The 214 is one of the last, well built, garden tractors, in my opinion. It replaced the 140 in '75. The Kohler is a solid engine. If it's in good shape-$500 ain't bad. Good luck!
    Seeing that the speed controller is broke-you gotta low ball him
    Aug 2015
    Idaho
    847
    A great day for some yard work.Click image for larger version.
ID:	230776Click image for larger version.
ID:	230777Click image for larger version.
    75' model 80 dump-cart & 69' 1020
    House Springs MO
    5,496
    Okay John Deere fans, my buddy has a 420 mower with the 20hp Onan engine. It surges (dirty carb), has a leaking oil filter adapter (east fix), and needs a deck belt and a couple of deck springs (again easy fix). He's not fond of working on things beyond changing oil and is tired of messing with it and wants $600 for it. It has about 1300 hours on it. Looking at the price of these things, they are not cheap tractors. Watchya Think?
    Sent from my SM-G900V using Tapatalk
    House Springs MO
    5,496
    Well I bought it. Lol
    I guess we'll see how it works out. I think I made out pretty good.
    Austin, Massachusetts
    1,591
    i was moving firewood in the yard today with my round fender 110. love the thing!!!
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    House Springs MO
    5,496
    Quote Originally Posted by redsox View Post
    I almost bought a round fender a few years ago when I was Jones'n for a green and yellow mower. It had the front mount snow blower both in perfect condition. He only wanted $500 and I snoozed on it and lost out. These tractors can be just as addicting as atv's.
    Oct 2007
    Minneapolis mn
    4,067
    Was just looking at a roundy today!
    House Springs MO
    5,496
    It's a 318, not a 420. I don't know why I thought it was a 420, but however, I bought it anyway. About 20 minutes worth of carb cleaning I had it running like a top and a new oil filter turned a steady drip into a dime sized spot since I parked it last night.
    It has a 46 inch deck that I have to replace the tensioner spring, but it's in really good shape.
    This is the first hydrostatic tractor I've ever owned so it's takes a little to get used to. I'm used to the foot clutch mowers.
    TrickShot's Avatar
    TrickShot is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2010
    Delaware County New York
    358
    My JD 214 project as I got it, will get some work soon. It's complete with the side panels which are on shelf nearby.
ID:	231313Click image for larger version.
    Blossvale NY
    4,563
    Quote Originally Posted by Jd110 View Post
    Wasn't the 140 a hydro??? Where the 214 is a conventional gear drive with a separate clutch and brake pedal as opposed to the 110 and 112 with the single pedal on the left that served as both clutch and brake. I always thought the 210 and 214 were the replacement/upgraded version of the 110 and 112.
    The 300 series were great tractors too. Every bit as well built as their 200 series counterparts. Same Kohler engines, only they were hydro... With the exception of the 322 and 330 which have in-line 3-cylinder Yanmars, one gasoline and the other diesel respectively.
    I was looking at the manuals I still have for my 330 diesel awhile back, tractor alone with no implements tips the scale at 850lbs, the manual for my 50" deck states its shipping weight is 150lbs, plus I have wheel weights. All fueled and ready to mow my old Johnny weighs over 1000lbs! LOL! Heavy little mutha!
    BKM: nice scoop with the 318
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Aug 2015
    Idaho
    847
    Yes. That's right. They are hydrostatic. Must have meant 214 replaced 110. 73' 110 must have had a separate brake option, as did the 140 H1 cuz mine has foot clutch on left and brake on the right.
    Aug 2015
    Idaho
    847
    Hey guys. If you don't already know, tractor data.com, has lots of info on these and the different engines they used on the 300 series. Sounds like by '83 they had they kinks worked out with the 2-cylinder onan.
  15. #30
    House Springs MO
    5,496
    I got a little hydraulic fluid leak coming from the rear that I can't seem to find. It's not bad, but enough to drive me crazy.
    My tractor is an 85 with the Onan B43g engine. It has 12xx hours on it, but runs awesome.
