Hello everyone,
This is my first post here on 3WW, but I've read several posts and love that this place exists. Anyway, I'm brand new to ATVs, and I've started out with a 1980 Honda ATC 110.
I had a guy rebuild the top end and replace the carb right around Christmas time. When I got it back from him, it ran like a top and everything was great. Then just recently, I started having no power whatsoever at full throttle, and it sputters and pops (backfires I think) until it either dies or else I let off the throttle. The problem is worse in 2nd gear and higher than it is in 1st, but it exist no matter what gear it is in. My spark plug was black, so I thought that maybe it was running rich, but it's weird that the problem is just now happening and didn't happen back when I first got it.
The new carbuerator is a Chinese knockoff of an ATC 110/ATC 125 carb and looks practically identical to the original in every way. However, I'm not sure if the needle and the main jet are exactly the same or not. The problem is that while I'm pretty sure that I still have the original jet, I'm not sure if I have the original needle or which of my two needles is the original.
Of the two main jets that I posses, I have one that says "82" on it and that I believe is the original, and I have another that looks pretty much the same to the naked eye but has "876" on it. The one with "876" on it is in the carb and has been ever since I picked it up.
However, I'm not sure which needle is original as the guy who worked on it reused the top cap from the old carb, and I'm not sure if he also reused the slide and needle or not. While the guy was a decent mechanic, he was extremely unorganized, forgetful, and kind of unreliable (I don't plan on going back), so I don't think there's any point in me asking him because he won't know. Anyway, the needles are actually quite different from each other, so I'm wondering if that's the problem. One needle is brass, thicker, has a more aggressive taper, and has "336536" on it. The other is a silver color, thinner, has less of a taper, and I'm not sure if it has anything stamped on it as this needle is currently the one in use.
So I guess I have a multi part question: 1) Does it sound like my problem really is that it's running rich at full throttle or is it something else, 2) If it is running rich, am I on the right track with the jets and the needle (I have no idea what I"m doing but have managed to take it apart and put it back together and get it running again), 3) which needle is original and/or the better needle to use, 4) does it make any sense that it ran fine all of January and February but is now giving me trouble?
The symptoms made me think that I need a smaller jet, but one thing is giving me pause. My manual says that the original jet is an 85. However, from what I've read online that was changed to an 82, so that explains why I have the 82. The problem is that the 876 is either the same as the 82 or maybe slightly smaller, but it definitely isn't bigger. That makes me think that I shouldn't need an even smaller jet because I am already at least one size smaller than what is in the manual.
One last thing. I removed the thinner, silver needle and adjusted the clip by one position so that the needle sits lower in the carb. Then I started it up and drove it around. At first, I experienced all the same symptoms and thought that the adjustment did nothing. However, after driving it for a few minutes, it suddenly started working fine. What do you make of that?
Sorry for the long list of questions. I'm new to this whole thing, but I do appreciate any help that you might give.
Thanks,
derrick81787
