Results 1 to 15 of 16
Thread: 200X seat re-recover. Finished product
    Mackus84's Avatar
    Mackus84 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2016
    Lakeland, Fl
    427
    Tackled re-covering my seat this morning before work. May not be a Moshman Masterpiece, but it came out pretty good IMO. No wrinkles, and only cost me $12 bucks. (Plus $40 for a donor seat with good pan and foam) Tools included hair dryer(a MUST), arrow manual stapler, razor knife, scissors, flathead screwdriver, 8mm staples, and quite a few cigarettes. What do yall think? I'll also be doing the stenciling. I cut the emblems off the original junk cover and plan on tracing them and making a stencil. What do ya'll think?Click image for larger version.
ID:	229101Click image for larger version.
ID:	229102Click image for larger version.
    Aug 2014
    South Louisiana
    1,915
    Looks really nice. Good job.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    Thanks. Have done it twice before, but this one came out alot better.
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    Ok so my 200x build has bern a little stalled out lately due to being extremely busy w 70 hr work weeks. Today i got around to stenciling the 200X on the side of the seats. I did it by making my own stencils out of the old trashed cover, then tracing paper and lines cleaned up, then stuck that to some double sided tape and cut out the lettering with a razor knife. I know they make stencils for it but this required 0 shipping and waiting or cost plus im more of a diy'er, plus i already had everything i needed to do it so it only cost me about an hour of my time. I think it came out pretty good, although one small spot on one of the X's pulled up a little. But i can touch it up if necessary. Heres a few pics.
    Old seat lettering cut out Click image for larger version.
    Traced logos on double side tape Click image for larger version.
    The now double side sticky Stencil applied on one sideClick image for larger version.
    And the other Click image for larger version.
    Right side finished Click image for larger version.
    Left side finished Click image for larger version.
    So its by no means "restoration quality" but for a restomod rider trike it came out pretty good and im happy with it. The HONDA on the back i also made a stencil for but its a pain to cut out all the tiny corners so thats on hold. I may just order the stencil for that. Anyways thanks for looking.
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    Its a 200X again!!!!
    BEFORE Click image for larger version.
    AFTER Click image for larger version.
    Aug 2015
    Idaho
    848
    Looks good. I'm sure all the work you've done will pay off.
    Btw. You got the same picture bug I've got!
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    Quote Originally Posted by Jd110 View Post
    Man it drives me crazy! I try holding the camera different directions and everything, sometimes theyre upright, sometimes theyre not. And its only here on 3WW. If you click all the way into the pic it flips over
    Slidell, LA
    4,738
    Get you an 85-86 ATC 250r white front fender and some 18 inch holeshots for the rear. Nice job so far.
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    ^^^^^^ That is a link to my build. And a white R fender and holeshots are actually EXACTLY the plan haha. Good call Yaeger. Those are just roll around rims and tires, i have brand new 8x8 3+5 polished wheels that i habe yet to get mounted, and i just threw the oem fender back on for the time being. Its a running riding trike at the moment. Build has been on hold for a bit but will be getting back to it soon. White R fender, holeshots, new levers, decals, Maier shrouds and SS brake lines are coming soon. It has beenCOMPLETELY torn down and rebuilt. Motor included. Top and bottom end 100%
    Feb 2016
    Stellenbosch, South Africa
    195
    If you want a perfect finish logo on your newly covered seat, I did mine with Silhouette CAMEO Smooth Heat Transfer vinyl .... you just cut out the logo and letters using a vinyl cutting machine and iron it on ...
    1983 Honda ATC250R
    1983 Honda ATC200E BIG RED (sold)
    1984 Honda ATC200E BIG RED
    1984 Honda ATC200X (sold)
    1985 Honda ATC70 x 3
    1985 Honda ATC250ES BIG RED
    1986 Honda ATC250ES BIG RED
    1988 Honda ATC250ES BIG RED
    1995 Honda Frankentrike 50cc 2-stroke
    2001 Honda TRX90
    2004 Honda TRX300EX (sold)
    2008 Honda TRX250TM
    1976 Suzuki RV90M (sold)
    1967 Vespa Primavera 125
    1958 Massey Ferguson 35
    Leevvii's Avatar
    Leevvii is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2016
    Australia
    216
    I am also recovering my 1984 200X seat, but i cannot get the staples to grab into the seat plastic, best i can get is for the staple to grab in about 1mm-2mm, but it will not seat down level with the plastic. Its a heavy duty staple gun. Any hints on how to get the staples to seat, or alternate methods of attaching the cover to the seat, ....help
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    Quote Originally Posted by Leevvii View Post
    I used a $15 arrow staple gun when i did mine. 8mm staples i believe. Just gotta hold the stapler stapling side down FIRM against the seat pan, and seat pan firm against your work bench/table
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    http://m.homedepot.com/p/Arrow-Faste...-T50/100021099 This is the stapler i used. So obviously doesnt have to be anything fancy. Although an air powered stapler im sure is much better. I had the same trouble as you for some staples. Just gotta pull em out and try again.
    Feb 2016
    195
    I use an air powered staple gun with stainless steel marine staples, shoots right in
    1983 Honda ATC250R
    2001 Honda TRX90
    2008 Honda TRX250TM
