Rear gear from a shaft yam200 on a 225 ?
I Know it's possible to put the gear from a 225 on a 200 but can we Take the gear from a 200 and put It on a 225 ? I want my 225 on tire 25" and change the ratio gear on the same Time. Some one havé done this befor? I read a lot but find nothin on this subject.
Shouldn't need to switch the diff for a little bit bigger tire. To my understanding. The 225 has a 15% higher diff.
As I understand though you need the 200 bearing carrier and main gear bolted into the 225 diff.
If you put the 225 on a 200 you need to change a nut on pinion shaft.
Facebook Yamaha ytm three wheeler group. Lots of guys have lots of different mods and stuff done to these things. Post this there as well.
Ok thank's for the information
I have 25 Inch tires on my 225DR with the stock rear diff. But if you just want to swap the diffs I believe it will bolt right in. I've read it before on this site.
//ArrowChat Integreation Code
