Also, when you installed the cam, you had the lobes facing down correct?
Update, after finding actual tdc I moved advance as much as I could counter clockwise and it nearly starts every time. Perhaps the strokes now changed because of the HC piston?
It now fires and essentially runs as long as I'm pull starting it, which is a breeze as it's firing and helping. But as soon as I stop pulling the cord it won't keep going. Plug is dry. Given my results (tdc is NOT the T mark for some reason and my ignition is retarded at maximum. Where have I gone wrong? I never pulled the flywheel or anything I don't even know if it was right to begin with. Should I scribe a new line at tdc and another just before? I'm starting to over think in my excitement so I need to step back.
Hmmm. That idk either. Unless you sheered the flywheel key
Check the flywheel key /magnets and stator. Somethings going on somewhere.
Did you ever figure this out?
So it's running, and it's running GOOD. I ended up finding true top dead centre, and I was three teeth off. Didn't bother with the markings lol. Thanks guys!
Good luck. Hopefully whatever reason the flywheel is off clocked from the crank won't cause you any issues in the near future.
I think you need to check your cam chain. It could be stretched. I don't recall you mentioning it.
