Thread: Ytm 225 dg exhaust jetting
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    What jets do I need to run a DG pipe on my 225?
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Aug 2014
    danville pa
    32
    my stock with dg exhaust took a 115 main jet only
    Aug 2014
    South Louisiana
    1,915
    You probably should be able to get by with just a carb adjustment
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Scootertrash's Avatar
    In the sticks
    4,638
    Every machine will be different. There is only one way to find out what jets your machine will run best with. Start at stock and follow the jetting process here:
    http://www.3wheelerworld.com/showthr...Jetting-Theory
    If you lucky, like Jmoozy said, you may get by with moving the clip on the needle a notch or two, along with a little adjustment on your idle air screw. No sense in buying jets until you're sure you need them.
