Results 1 to 15 of 48
Thread: THE TF 2016 "Swap Meet" thread
    Thumbs up THE TF 2016 "Swap Meet" thread
    Ok boys and girls it will be here before we know it so post up what you are looking for, cause there will be people coming from all over to ride and BS. So post what you want to find or sell it don't have to be atc related cause alot of us are into a lot of differant things.
    Mexico
    9,014
    I've got a few things I'd like to get rid of, but nothing I want to cart back home afterwards. If anyone is interested in the following please let me know via PM and I'll shoot you some better photos.
    22-11-8 tires (2) - Kenda Scorpion - 10 hours use (max)
    85 Tri-Z OEM rear fender, black, no cracks, black hides nothing, but they still look pretty good, they are dirty in the photo.
    85 Tri-Z OEM front fender, black, no cracks, same as above
    85 Tri-Z OEM head light, black with guard and headlights, but the wires were cut at the connectors and the temp light has been removed
    85 Tri-Z swing-arm, stock length with good bearings and bushings. Metal was cleaned up before chrome PC and clear PC were applied, clean and ready to bolt on. Also have braided SS line to suit.
    85-Tri-Z stock throttle cable (Not sure of condition, housing may be rough)
    85-Tri-Z DG pipe, used, bare finish, some surface rust, but no dents
    85-Tri-Z fork gators, black, no tears
    YTM rear brake cable, did not fit 200K, might be for a 225? Contact me for length
    YTM 200K triple clamps
    YTM 200K forks, clean, grey PC lowers,some specs of chrome have lifted near the tops. May not be perfectly straight, but no more than .08" bent if at all. Fresh fluid, but they do make noise when they top out. I have the axle as well. Gators and caps not included
    YTM carbs, OEM, have flange and clap style, they would need gaskets
    I also have a fair bit of 03-04 Suzuki GSXR 1000 parts and 00-02 KTM 250/300 parts as well as a few stock 83 GS 1100E parts I'd be happy to part with.
    I can only bring so much over the border, so no promises. Let me know and I'll try my best.
ID:	229205Click image for larger version.
ID:	229206Click image for larger version.
ID:	229207Click image for larger version.
Name:	Fenders and headlight.JPG
    It sucks to get old
    Dec 2012
    greenville oh
    68
    What do you want for the two tires 22-11-8
    Queef Chief's Avatar
    Queef Chief is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2015
    Rineyville, KY
    231
    250sx forks with triples
    250sx seat pan (foam may be usable)
    250sx Stock silencer (baffle removed)
    2 22x11x8 tires off SX (still plenty of life)
    1985 250r air cleaner box w/lid
    86-87 Tecate rear plastic(aftermarket)**Pending**
    86-87 Tecate front fender(aftermarket)**Pending**
    86-87 Tecate shrouds(aftermarket)**Pending**
    Mystery pipe that came on Tecate (possibly factory pipe that has been modified)
    Tecate stock silencer **sold**
    May do some trading, or looking to purchase:
    '86 Tecate carrier
    '86 Tecate headlight lense
    '86 Tecate headlight switch
    '86 Tecate aftermarket flywheel
    '86 Tecate case saver
    '86 Tecate intake
    '86 Tecate overflow reservoir
    '86 Tecate rear wheel
    Buffalo, NY
    1,994
    I'm interested in your tecate parts queef, could you pm me pictures of the plastics and the pipe?
    My brother is looking for a TRI-Z rear skid plate.
    Apr 2012
    USA
    4,133
    Subbed to see what people are looking for.
    I'll probably bring along my harness tools again and offer new harnesses, adapters, etc. I'd like to offer harness repair, but I do a lot of riding too so not sure how well that will work out. If you need a connector added back on your harness, stator, etc, shoot me a pm so I can gauge the interest and exchange the best way to communicate at the event. I'll have a smart phone with "limited" internet access due to poor signal. I'm thinking repairs will range around $5-10 based on the situation.
    For used parts I have a ton of parts, too many to really list, but I'd love to get rid of some of the larger harder to ship parts.
    Quick run down on what I have purely from memory
    85 Tri Z Swing arm with blown out shock
    ~83 185s frame, has blue over spray but good shape (no title, not required in Michigan for its age)
    83-85 200x frames, should have spare swing arm/axle parts too
    185s bottom end, never had it running, but seems to shift though the gears just fine
    ~70-71 US90 bottom end, again never heard it run but it seems to shift fine though the gears by hand
    I have a Suzuiki 125cc quad that needs a vacuum pump in fair shape too. It's an older machine, don't have the year on hand, Fenders were painted and droopy, maybe cracked a little don't remember 100% for sure. I do remember it being a smoke machine so the top end needs re-worked (rings I'm assuming). Not planning to bring it unless there is interest.
    Camp location was down at the pond last year, I'll probably try to get the same general area again. Basically down the hill from the main building and to the left at the fork. Gray/Silver T100 Pickup with a black topper and likely a dark green Tundra near by. Maybe a 4runner or two depending how things work out.
    Mexico
    9,014
    Quote Originally Posted by jimthetruckdriv View Post
    I'd like $50 for the pair. If that seems high let me know, their just taking up space here, but they are in close to new condition, you can see them in the picture of the yellow trike.
    It sucks to get old
    Mar 2011
    Red Lion pa
    1,542
    If jimthetruckdriv passes on the tires I'll take them. Perfect for the KLT's
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 black (project)
    86 klt 185 red
    85 klt 160 (Floyd)
    85 klt 110 X2 (projects)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    kiser's Avatar
    Coshocton Ohio
    525
    I have a 85 Tri-Z headlight that is rider quality. It fits and functions fine but has a couple flaws. It comes with a top triple that is in great shape. Make offer or trade for ??? It's just taking up space so let me know what you have.
    Van down by the river
    3,874
    I am coming early and leaving early again this year but am happy to bring along anything. Thousands of parts here. What do you need?
    Many motors including atc 70, 90,110, 185, 200, 200e, 200es, sx big red and 3-4 350x bottoms.
    Rear fenders ,forks
    86 running 200x, oem plastic! $1000
    1 auto x project 90% complete $350
    1 84 200x roller $150
    87 125m frame very nice for $50
    1 250r 83/84 bottom dirt cheap$25-sold
    almost a complete Kawasaki 110 in parts-no tank
    Like new 250sx front knobbie tire mounted on nice clean rim $65,
    Full part out of 86 350x, shall i go on and on?? I also have new design T-shirts and hoodies!
    350x rear mud flap garnish
    250sx new headlight guard-$65 white in color and still in the package
    A full sx part out
    Very nice set of 3 knobbie tires mounted on sx rims
    83-84 250r forks
    81-82 R forks with triples
    350x front rims both 85 and 86! Both have tires mounted.
    Message me or call me. 2173704573 i can send pics if needed. Thanks to mr jason spect for starting this thread.
    R.I.P. John Swinehart
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    Manitoba Canada
    95
    In a dream world someone would have a rear set of 86 350x fenders and nos 87 200x rear fenders?
    3,874
    Quote Originally Posted by Thunder God View Post
    Better luck playing power ball.
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    May 2007
    Coshocton, Ohio
    1,815
    Quote Originally Posted by captainweezy View Post
    I am coming early and leaving early again this year but am happy to bring along anything. Thousands of parts here. What do you need? Many motors including atc 70, 90,110, 185, 200, 200e, 200es, sx big red and 3-4 350x bottoms. Rear fenders forks, an 87 125m frame, 1 250r 83/84 bottom dirt cheap$25! Comes with shifter for free (welded on lmao), new never used first gen 200x maier full fender set with nice seat. Includes tank scoops and front/rear fender $250. New sx front knobbie tire mounted on nice clean rim $65, full part out of 86 350x, shall i go on and on?? I also have new design T-shirts and hoodies!
    man, when are you leaving this year?
    Appalachian American Racing
    the home of
    3,874
    Quote Originally Posted by Daddio View Post
    Sunday to tuesday/possibly wednesday
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
