I have been slowly selling my trikes over the last couple of years as life takes its toll in time, motivation and many other aspects. I had an 85 Z, but it just never really did it for me. It was ported, piped and had a 38mm carb, so it ran well, but just wasn't my ticket. SO after I found this bike and bought it in 2012, I sold the 85 as I love the 6 speed and the suspension. But it went to a good home. https://www.youtube.com/watch?v=PU9d...e_gdata_player
This is one of the handful of bikes I am going to keep. This bike came from the original owner, with the original tires, bars and thumb throttle included and was on the original bore. His parents bought he and his brother matching bikes to keep at their lake house in 1986. His brother trashed his, and the owner of this one never really got into trikes as he preferred bikes. The lack of paint rub on the frame and on the front forks, as well as the original tires led me to believe most of his story. The twist throttle, bars, rear tires and silencer were the only non original items.
I put a new piston in as it was slightly out of tolerance for roundness and have only put about 8 hours on the new bore. The cylinder was untouched, no porting and the carb is stock with stock jetting and this bike runs as well as my 85 did, and also better than the 86R I had previously sold. Anyway, I noticed that the clutch would slip just a little, in top gear mostly, and when the kicker was lazy on the return trip a couple times, I decided I should get that ironed out before spring.
I USED the search engine but my particular question didn't seem to come up in the first 250 or so threads. The kicker will rotate slightly farther than it should from the stored position before feeling like it engages and when it returns, does not return all the way to the top. As far as I can tell, the gears all look operable and the return spring is intact and was seated in the holding hole. The parts installation order checked with the parts fische and the kicker looks identical to another 86 setup I have. I have heard that they can bind up because of the small cover gasket, but it was not clarified if that was on return or on the downstroke. The bike starts easily and the kicker returns about 2/3 to 3/4 of the way and will pull back up by hand with very little effort. It does not fall down to the engagement point, it is not loose and it isn't that feeling where it is engaged, but the piston isn't on compression. Here are some pics. Is the small spring clip (#3) supposed to be on the CW side of the shaft stop, engaged in the hole in the case at approximately 3 o'clock, or on the CCW side as shown in the parts fische. I could not tell where it was located when I removed the shaft and it will turn in the groove.![]()
