Pretty sensitive aren't you?
I'm not trolling. I'm asking questions to find out how you came to your conclusion. You didn't say which motor you were talking about, so I had to assume it was one of your non running motors.
I'll ask you again, like I've asked in your other threads "DO YOU HAVE A
SERVICE MANUAL?"
Adjusting the screw by the dipstick won't change the amount of play in the shifter. It's for adjusting the clutch. The operation of the clutch has nothing to do with the play in the shifter. THERE IS NO ADJUSTMENT FOR PLAY IN THE SHIFTER.
DO YOU HAVE A
SERVICE MANUAL?
If your clutch plates are worn out of spec, you will not be able to properly adjust the clutch. If you can't properly adjust the clutch, guess what? HARD SHIFTING
DO YOU HAVE A
SERVICE MANUAL?
Have you checked the splines on the shifter shaft and inside the shifter lever to be sure that the shifter lever isn't slipping causing what you consider to be excessive play?
DO YOU HAVE A
SERVICE MANUAL?
From the Honda Service Manual/Clutch Oil Pump Chapter/Troubleshooting
HARD TO SHIFT
1. Stopper plate damaged
2. Incorrect clutch adjustment
3. Faulty clutch lifter
From the Honda Service Manual/ Transmission Chapter/ Troubleshooting:
HARD TO SHIFT
1. Shift fork bent
2. Shift fork shaft bent
DO YOU HAVE A
SERVICE MANUAL?
All of these potential causes of your problem can be inspected, diagnosed, and repaired BY USING THE
SERVICE MANUAL
Guess what? If the
parts in your 185 are out of spec, you can use the
parts in your newly purchased engine without a top end (if they are present in the engine and in spec), to repair the shifting issues in your 185 so you have a running auto x while you make sure the other 200 is running or capable of running instead of wasting all the time swapping out and engine that may not run.
DO YOU HAVE A
SERVICE MANUAL?
F'n Millennials. You want everyone else to do the footwork for you and when you don't hear what you want or get what you want "It's not fair!! Stop picking on me!! Jesus H jumping Christ on a pogo stick.
You know why a lot of mechanical/repair/diagnostic questions get very few responses?
A. Because 99% of them have already been answered multiple times and the answers are easily found using the search function. But then someone would actually have to do some reading to find the answer. Waaaaayyy too much work.
B. Threads like this where young punk, wet behind the ears know it alls ask for help, then disrespect the ones trying to help them, or even better yet? Tell them they don't know what they're talking about.
Oh Yea, did I forget to ask: DO YOU HAVE A
SERVICE MANUAL?
