I sure missed that one; NO SILENCER? They run ridiculously HOT!! Thru this whole blowing up time span of doom and gloom, you never ran a silencer??
If you don't mind spending money, get a new carburetor.
No leak test after this?? No checking of the bore and piston at any machine or motor shop yet??
Your crank will be toast soon. If you supersize any of your pictures, there are pieces of aluminum everywhere, and they keep happening.
Dents where the wrist pin got either installed or removed incorrectly (note the dings or peening) on the piston wrist pin hole appear to be from a
Do you know how to make a safe wrist pin remover very easy??
See how hot that wrist pin got. Scratches all over everything.
A 4 stroke would be much more difficult than this.
SIMPLE
1) Put the damn silencer on!!
2) Have the bore and piston checked for clearances.
3) Put it together lightly coating the piston with 2 stroke oil.
4) Leak test it AGAIN, even if you already did it once.
5) Brand new carburetor with stock jets. My Keihin for my 2 stroke Hondaster brand new one was 188$.
