NOS needle? You do realize you can buy brand new Keihin needles right? Even a brand new carb, the same model that was used on these trikes.
I made a lot of assumptions, obviously assuming that the jetting was anything close to useable on a trike that I bought in non-running condition was not the best of them.
It was not a crank bearing. Forcing that bearing in was not in any way ideal, I was stumped with what to do at the time, and already stressed out enough over other things. Again, my mistake, no sense in calling me out on it now. Transmission is put together as it should be, thrust washers in the correct places, shifts through all the gears. I do have my doubts about it, using a bearing that is not OEM for one, not replacing every bearing with a brand new one, shift forks with irregular wear due to past mistakes, etc.
I mentioned it before, I already bought 3 different sized needles ranging from rich to lean. Going to use that as a starting point before i do anything else. Everyone in this thread kept pushing pressure testing is why I was posting about it, FYI.
HOLD ON LET ME COOK SOME POP CORN FOR THIS SHOW
Sent from my SM-G935V using Tapatalk
Saying "it's the trikes fault" is like saying "guns kill people"
don't poke the bear... you'll get banned
Well, 8 pages- 108 replies- 1,909 views and it still runs the same as the day he bought it.....I wonder why???
By the looks of the piston...you have a 4 corner seizure.
Look up the causes.
"You should never smoke in pajamas..
You might start a fire and burn your face..
Maybe you should return to Manaugua..
You could go un-noticed in such a place"
FZ
Ass,gas or grass....nobody rides for free!
Ride free,Brotha. See you in Heaven.
Man, I have absolutely refrained from posting in this, because it seems like anything that is said either A) goes completely into the I Know everything, Ignore category or
B) is an absolute attempt at derailing a thread further into the caticasim of confusion and uselessness.
If barnett had stumbled into this it would have been 128 pages by now. I guess so far, this is the only positive this had going for it.
Now having interjected my worthless smart ass comments and opinions...
I have assmebled too many engines to count, cars, cycles atvs 2 strokes and 4 strokes.
I have never, I repeat never had to hook up a bunch of leak down crap....ever
If you dont know the symptoms of a vacumm leak by the way the machine runs, you probably should not be building engines, plain and simple. And to be honest, whenis assembled correctly, step by step of the
service manual, not by opinions of internet sepculation, using the proper tools, there is about a .000002 % chance you would ever have a air leak.
Now I have fought issues that are straight up crazy, and asked questions to knowledgeable people, and took the info, applied it, and learned something, either good or bad. There are issues out there, that some just need to find just one guy, that had the same problem, that was so isolated that only the internet could tie the same 2 incidents together. That is not the deal here. This is only thread number 6 million of piston seize on the internet....
It is a 4 corner piston sieze here. (6 MILLION AN 1) This is not that friggin complicated.
So now, for my internet expert assessment based off pics and thread content....
A)There is a clearance isssue with the bore
B) owner is impatient and not taking proper steps to break in the piston and jug before it siezes
C) jetting needs to be put back to.....well see my signature.....and if it only runs for 10 minutes, there can be no jetting adjustments in 10 minutes and is all speculation at this point...
D) all theabove...
Choose wisely...this for all the marbles.
Seriously though, if I came to a forum, posted being pigheaded stubborn for suggestions, as a assisting member I would have stopped giving advice on page 3....out of pure sanity. ..
Ever answer has been posted here. Every possible scenario for this guy's problem has been layed out in this thread. If it does not get corrected, the answer as to why is painfully obvious.
If I came to a forum, and ran into derailing comments, for my problem, I would shut the friggin monitor down and get out there and figure out myproblem on my own, like we had to in the old days when there was no internet to go to, and a undying need and want to ride, over trumped useless hours pissing back and forth on the internet. ...But somehow I feel this will go on at least 4 more pages before it goes good, or gets worse....Please prove me wrong.
Proudly NOT a member of
"Team on the Teat"
Garbage thread. Here's an idea, there should be a special place here for this type of garbage so it doesn't taint the rest of the site.![]()
Appalachian American Racing
the home of
