Make sure to get a new cam bearing and washer for new cam!
There have been alot of questions surrounding the camshafts used on these models lately.
I thought going over all 3 variants of these OEM camshafts in one post would be helpful to many and answer some of those questions.
Camshaft Part# 14101-965-000
Status: Still available from your Honda dealer as of 12/09/04
This camshaft is used in ALL of the ATC 185/200 series engines except for the '86-'87 200X engine.
And yes, the '83-'85 200X cam IS the same as all the other ATC 200 models.
1980 ATC185
1981-1983 ATC185S
1981-1983 ATC200
1982-1983 ATC200E
1984 ATC200ES
1984-1986 ATC200S
1984-1985 ATC200M
1983-1985 ATC200X
1984 TRX200
Camshaft Part# 14101-446-000
This camshaft is used in ALL XR versions of the 185 and 200 dirtbikes up to the 2002 model year except the '84-'85XR200R.
1979 XR 185
1980-1984 XR 200
1981-1983 & 1985-2002 XR 200R
Camshaft Part# 14101-437-000
Status: Discontinued at one point but currently available in limited Qty as of 12/04
This camshaft is used exclusively in the dual sport bikes and has a higher lift and duration than the XR version camshafts.
1979-1984 XL 125S
1979-1983 XL 185S
1983-1984 XL 200R
I also read that the stock 200X cam is actually bigger than the bike cams but the bike cams are better for low and mid-range power.
