Results 1 to 9 of 9
Thread: New project questions
    Mar 2016
    Nebraska
    3
    Hi guys, I'm new around here. I have what I think is a 79 Honda 110. So far it runs and rides great, I have to replace the front tire at some point. But other then, what I really came here for is, it didn't come with a headlight, the mount is there but none of the wires are there or anything. What Im wondering is, is there a aftermarket headlight I could mount too it? Anything really bright that I can put a toggle switch on would be great, and how do I wire the thing up? This is all pretty new to me. Thanks in advance for any help.[ATTACH=CONFIG]229628
    Mar 2016
    Oklahoma city
    26
    Looks like it has a '74 atc90 tank on it.
    Headlights are available online through the usual sources. You can find a wiring diagram on this site.
    Apparently there is a classified section here, but I am not able to confirm as I am new to the forum.
    Mar 2016
    Nebraska
    3
    From what I understand the first year of the 110 would have been 79, and yeah the tank probably isn't the original, I got this trike from a guy who was using this one for parts and then slapped a bunch of other parts together to get this one running again.. And thank you, il look around some more for some wiring diagrams.
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    It sound like you are not looking for a replacement headlight?
    Obviously those are a dime a dozen on Ebay.
    You want something mega bright!
    I have not come across any modifications like that.
    You may be stuck with something like this?
    http://www.ebay.com/itm/1979-1985-HO...dWo~Z6&vxp=mtr
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    Feb 2016
    Georgia
    66
    If your going aftermarket then go LED.
    That is my beast with just the low beams mounted. I later put a brighter flood/spot combo led on top for the hi beam.
    Mar 2016
    Nebraska
    3
    Yeah, I'm not looking for a replacement headlight, I'm looking for something aftermarket that will be bright as can be. But I'm confused by wiring it all in. I tested the taillight and it will work I'm sure, is there a way I could just wire into it?
    Mar 2016
    Old Hickory TN
    16
    They make some 6" and 8" led rectangle lights
    Sent from my 0PM92 using Tapatalk
    Mar 2016
    Old Hickory TN
    16
    http://m.ebay.com/itm/301682996347
    Jul 2016
    Canada new brunswick dieppe
    6
    were can i get afthermarket triple tree and forks for a atc 90 Nicholson frame
