I love ramming torch tip cleaners thru my soft brass precision drilled jets. Its way more fun guessing what they flow instead of using the littler numbers they have.![]()
85 Tri-z Basket Case
men have dicks.........some girls do too!
The brass is hard enough that you would really have to work the jet to make any difference. I'm not suggesting you humid in there and actually enlarge the hole i'm not suggesting you jam it in there and actually enlarge the hole just use it to lightly clean the jets.
i blow my jets out with acid....then I use compressed air
This guy blows this jets out differently https://www.youtube.com/watch?v=euXQbZDwV0w
yea, that's leaner than a yoga convention.
you need to fatten it up about 3 sizes to start. that should get you in the ballpark. remember the main is just 1/2-wot throttle. the low to mid is needle/mixture with idle jet. looks like she runs fat down low and thin up top.
picture a turkey. fat body and thin next. that is what you got. you want to lean the bottom out some and thicken the top to be more of a Pamela Anderson style.
if you want to manually enlarge the hole, get yourself a set of piano wired drill bits off ebay. should be around $10 for 3-4 sets shipped. you can then put the bits in backwards into the jet hole till you find the size and then drill using needle nose and a paper towel holding the jet. use the needle nose to turn the drill bit. remember in those the drill bits are about 1.5 sizes in each direction. so if you want to go 3 up as discussed. go 2 sizes on the bits up.
God speed!!!!
________________
https://www.mikesatvfix.com
"Roll on 3"
RIP Ol' Deuce
"Long Live the ATC"Building: ATCr125xRiding: ATC200sx"I am not a mechanic, mechanics get paid for this. I do it because I enjoy it."
Isn't "Plug Chop" one of the members here?
Pork Chop is Ironchop's son. I've met them both at TrikeFest. If I remember, he fouled a plug in his Tecate. Maybe we should have called him Plug Chop instead.
