Thread: 1997 KX 125 Bottom end rebuild cost
    Jan 2016
    Arkansas
    56
    I have a 97 Kawasaki KX 125 that needs rebuilt. The bottom end bearing needs replaced. The top end is Still good.
    What I want to do is replace the bearing in the bottom end and put it back together with all new gaskets and piston rings for now until I do top end again. Any Idea what something like that would cost if I had someone else do the bottom end ? I get paid tonight and would like to have my bike back, it's been tore down since December
ID:	229793Click image for larger version.
ID:	229794Click image for larger version.
    Sent from my XT1097 using Tapatalk
    1985 Honda 200x
    1984 Honda 200x ( 185s Engine )
    1997 Kawasaki KX 125
    Things change, doesn't mean they get better.
    Jan 2014
    Massachusetts USA
    782
    My machinist charges $75 to press the crank apart and put it back together and true it. A rod kit usually goes for about 100, and a crank bearing and seal kit is usually about 60. Add another 40 or so for a gasket kit, and there you have it.
    1985 Tri-Z 250
    1985 ATC250R
    Jan 2014
    Massachusetts USA
    782
    Buy a crank kit, it comes with all the gasket and orings and everything needed to replace it all and is normaly cheaper. I just did it on my KX100 and it was $130 or so bucks shipped with new bearings and new crank.
    That would be a cost effective method, if anyone offers a complete kit. The trouble I always run into is my stuff is too old to get full cranks from the aftermarket.
    1985 Tri-Z 250
    1985 ATC250R
    N/A
    5,818
    well considering last year i rebuild a 1984 kx125 with hot rods crank your bike is easy. go to ebay or start to look at replacement parts before you buy. try rebuilind a KX before 1988...lol and there are tons of parts for them too.
