Results 1 to 15 of 24
Thread: 200x front brake rotor install
    Aug 2015
    Jupiter, Fl.
    73
    So what gives? What am I missing? Pics show the hump/bump or whatever you want to call it in the same place. Caliper has new pads. Rotor won't go on
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    N/A
    5,818
    your missing a front axle spacer up front, that's why its doing that. www.partzilla.com to see how it all goes together
    Aug 2015
    Jupiter, Fl.
    73
    I have the spacers. Everything is fully disassembled now. The problem is the rotor will not fit in the caliper. Just trying it on by hand. There were no brakes on this bike when I bought it. I replaced the piston seals and the piston now fully compressed for installation. New pads as well. I have the shop manual for it and everything is in place and matches the pictures but the rotor will not fit.
    Aug 2015
    Jupiter, Fl.
    73
    From what I can see the hump is the problem blocking the rotor but it's supposed to be there according to all the pictures.
    The Open Road
    4,730
    The hump just barely clears the rotor when the front end is altogether. Pull the caliper toward you as you are looking at it like the above pic is oriented. The caliper is supposed to slide freely on those pins so the caliper works correctly. If it won't easily pull toward you enough to get the rotor to clear the hump, then you need to take caliper off the pins and lube them. Sometimes a bent bracket is the cause of calipers binding.
    In the photo the caliper looks pushed outward toward the end of the pins. Pull it in towards the bracket and try again
    Sent from my Z998 using Tapatalk
    Aug 2015
    Jupiter, Fl.
    73
    Oooooh. I'll try that tomorrow and post back. Thanks.
    Jan 2014
    Massachusetts USA
    782
    Are you sure that's the front bracket, and not a rear caliper bracket attached to a front caliper? I remember from my basket case build that the brackets are different. I'm in the house for the night, but I can look tomorrow through my extra parts box if you need parts pics.
    1985 Tri-Z 250
    1985 ATC250R
    Aug 2015
    Jupiter, Fl.
    73
    It mounts up correctly and looks like the pics I've seen. If you happen to have an extra anti rattle spring and shim I'll buy that from you. Hopefully I can get these slides unfrozen.
    May 2009
    S.E. Michigan
    1,251
    Ironchop has it exactly right: your caliper needs to slide on the rails further inboard. Below is the pic of mine showing how much more inboard the caliper is compared to the bracket.
    You need to make sure that the caliper can slide on #8 and #10.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Jan 2014
    Massachusetts USA
    782
    Quote Originally Posted by redemn93 View Post
    I'll take a look in the box, if I have them they're yours for the postage. Stay tuned.
    1985 Tri-Z 250
    1985 ATC250R
    Aug 2015
    Jupiter, Fl.
    73
    Quote Originally Posted by YTZ drew View Post
    Awesome. Thank you sir. I'll include a few extra for your time.
    Mackus84's Avatar
    Mackus84 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2016
    Lakeland, Fl
    427
    The anti rattle clip and shim are still available through Honda. Just thought id show ya. Every front caliper part except the actual assembly and original pads are. At least from the look of this fiche.
    http://www.servicehonda.com/parts/lo...65DAF14965D08A
    Aug 2015
    Jupiter, Fl.
    73
    The other pin came out easily. Then I found the stuck pin. This is after scraping it with a flathead. Sitting up soaking in blaster overnight. I'll refill in the morning if it's gone. I already rounded out the Allen head. I should be able to drive a 1/4 Allen key into it tomorrow and give it another shot. An impact may actually do the trick. If not, time for a new caliper.
    May 2009
    S.E. Michigan
    1,251
    Keep in mind that the caliper slides on that pin, so if you can figure out a way, just press it out of the caliper. No need to unscrew it to get the caliper off the pin. The hex is just there to unscrew the pin from the bracket. They can be a real PITA, but work it back and forth and it should come out.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Aug 2015
    Jupiter, Fl.
    73
    Good point. Thanks.
