Results 1 to 3 of 3
Thread: automatic vs standard shift. final drive ratios.. someone care to help?
    Apr 2013
    3whinerworld.com
    85
    Ok, so ankle deep into a franken quad project for my girlfriend (yamaha blaster + yamaha bravo 250 sno machine) = yamaha trail blazer lol.. anyways, trying to figure out the final drive ratio, I'm using the polaris trailblazer as a benchmark. it has (in stock form) a 2.68 reduction in the transmission, and 3.45 sprocket ratio. now those do add together right? as im getting a final drive ratio of 6.13 : 1 which is double what most quads have of 3.45 or so. I can only assume that the cvt transmission has an overdrive nature to it of somewhere 1:3. and needs that wholey crap gearing to make the final drive 3:1ish. that about right? and secondly the bravo has a 1.69:1 reduction. so assuming the clutches are the same size in the yammi vs a polaris, I would need to have a 4.44:1 sprocket ratio. to come up with the extra gearing from the low reduction of the yammi gear box. which is doable 12/52 will net that. but is all that correct? just seems weird to me they would have that much reduction..
    Jan 2014
    Massachusetts USA
    782
    When dealing with ratios, the math is always driven teeth ÷ drive teeth (or driven diameter ÷ drive diameter if using pulleys). Work out the individual ratios then multiply them (2.68x3.45=9.246) so you may need a steeper sprocket ratio than you think. Also, CVT's usually give very little overdrive, something to the tune of 0.8 : 1. My guess is Polaris used the steep reduction to allow full primary clutch engagement at low traveling speeds, to prevent slippage from prematurely wearing out the belt.
    1985 Tri-Z 250
    1985 ATC250R
    Apr 2013
    3whinerworld.com
    85
    yup.. sure looks like i'll need a deeper rear drive that way. on that math then, Polaris final drive 9.246 benchmark (a quad 100lbs heavier) divided by the yammie 1.69 = 5.49 which is a bit much for a rear sprocket, as the largest I can go that im seeing is a 11/52 combo netting 4.73. now big if here, If I could find a 12/23 sprocket set on the yammie gear box that would give me a 1.92 primary reduction. leaving 4.82 for the final drive sockets, which 11/52 will be close with a 4.72 ratio... anyone know if I can fid a set of yamaha gears like that?
