Thread: 200x bottom end, need help!
    Mar 2013
    Missouri
    97
    I was cleaning the chain side of the engine case, and these fell out. Where do they go?? And how do they go in?? Please help someone. Thanks!!
    Williamstown PA
    5,825
    what year 200x? Not sure off the top of my head but go to partzilla.com and look at the factory schematics which are free with OEM part numbers. From there you can see where they go.
    I cant remember if I had them in my 83-85 motor or not
    Mar 2013
    Missouri
    97
    It's an 85. I actually figured it out. They go inside the cam chain tensioner. Thank you for your help
    May 2015
    San Antonio
    12
    Geez, looks like the insides of Vader's helmet.
    Oct 2016
    New York
    118
    Cam chain tensioner, those two lay together and set the correct tension. when the motor is running you loosen the bolt that screws into that set up and it sets the correct cam tension. Then you tighten the bolt back down to the specific torque. Don't quote me but i think its around 12ft lbs.
