Results 1 to 12 of 12
Thread: 200es drum brake turning?
    ericmreimer's Avatar
    ericmreimer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Splendora, TX
    296
    I'm fairly new to the ATV scene and have never done ATV brakes, plenty of car and truck drums, drum disc conversions and so forth in my past . It doesn't look like rocket surgery or anything on how to service them, hardest part was getting the front axle out. Haven't put it back together yet and the drum is within service range according to the manual. I hit it with a quick 220 sand paper to clean up the glazing, cleaned the drum up and it looks pretty good....new water grooved shoes and cables.
    My question is is it normal to turn the drums on ATV or do you think I'm good?
    1984 Honda ATC200ES saved
    Project in progress 1984 ATC200ES with Trx200 rear suspension/200m front suspension
    Mar 2007
    Texas
    5,045
    my local autoparts store was able to do mine for drum turning.
    I typically only turn the drums if there is a reason, E.I. pitting, scoring, groves, and such. if not, what you did should be fine.
    ________________
    https://www.mikesatvfix.com
    Jul 2013
    Splendora, TX
    296
    Great, i'm going to slap it together and see how it goes. thanks for the reply.
    Mar 2015
    Nashville, TN
    26
    90 grit garnet paper works good for me to put a new surface for the shoes to grab.
    TTown, Alabama, United States
    845
    Id pull the cam out and polish it up with some fine sandpaper and grease it lightly while you have it apart, to prevent sticky/slow brake return. In my {limited} experience, they usually have some scoring going on and it only takes a few more minutes to get it looking new again.
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    When the going gets tough, the tough get sideways
    Mar 2007
    Texas
    5,045
    ^ true, i did forget to mention that. i also do a thin grease layer on the cam before reinstall. use new felt seals for it too (or make some from other felt)
    ________________
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    Quote Originally Posted by ericmreimer View Post
    Thus quote Dr. Frankenstein.
    Sorry for reaching for the low hanging fruit...
    Jul 2013
    Splendora, TX
    296
    Great Idea! I'll clean and lube up the pivot arm as well! I have it back together but its coming back apart pretty soon for a different set of forks anyway.
    Thanks for the advise!
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Sorry, but what is turning?
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    334
    "Sorry, but what is turning?"
    The inside of the drum is turned on a lathe to cut a new smooth surface for the best braking performance. It seems to be a fading service with cheap chinese rotors and drums.
    May 2015
    1,081
    Quote Originally Posted by JustEnough View Post
    Thanks never heard of it so I didn't know
    Jul 2013
    Splendora, TX
    296
    New brakes are all done. Water grooved shoes, new cables and all cleaned up. Much better! I didn't turn them, they didn't really need it. Click image for larger version.
