Results 1 to 11 of 11
Thread: Rack restoration?
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Rack restoration?
    I'm wanting to repaint my front and rear racks along with the head light guard on a 200es. I asked someone I know if they can sand blast it but they might not because their sanding box machine might be too small. I'm awaiting their reply. So what oaky remedy can I use to get rid of the rust and prep the racks?
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Apr 2014
    wisconsin
    146
    get busy with a wire wheel on a grinder. It will suck. Ive used paint stripper and ive never liked it. I never got somthing stripped nicely using that stuff.
    Mar 2003
    Australia
    1,919
    Take it to a sandblaster that can fit it in their cabinet. Only way to properly do it, that or have it chemically stripped.
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Mexico
    9,018
    Elbow grease works, especially if you plan to spray can it. In that case you don't want to remove any good existing paint as it will be better than anything you can add from a can, just get the rust off, but blasting them and getting them powder coated is the way to go if you want it to last for years to come. Are you adding any hooks or loops? I always thought stock racks were lacking in that department. If so, now is the time to do it.
    It sucks to get old
    NEPA
    7,051
    Ever catch the top of your foot or shin on those rear racks El? Can Ams come stock like that ,and there is a def learning curve to mounting one properly
    Williamstown PA
    5,825
    Sand blast and powder coat.
    Oct 2013
    Wherever I May Roam
    3,757
    3"Orbital sander and time is another option. There are also spot blasters but they are messy. If you are using aerosol, I like VHT Roll Bar and Chassis paint. It is extremely durable.
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    if you are doing to sand it , get some sanding sponges from the paint store .
    May 2015
    1,081
    I think I'm going to take a wire brush to it I've got a hand held so it'll be easy. And if the paint peels off I'll just spray over it again
    Mexico
    9,018
    Quote Originally Posted by atc007 View Post
    Can't say I have, but that's not to say I won't some day That rack is of unknown Yamaha origin and is a lot larger than the stock rack. Never could figure out what good the stock rack was for short of a hay bale or a deer corpse, so the stocker was cut up to augment this rack.
    It sucks to get old
    May 2015
    1,081
    well. I'm wanting to out some ammo cans on the rear rack one on each side like the one in the pic. I was going to weld them on but someone I know mentioned making brackets so I can take them off when needed
