Results 1 to 15 of 54
Thread: Plug chop
    averysdad is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2013
    Cleveland, tx
    218
    Plug chop
    What's the best way to cut the threads of the plug without braking the white part Now I know y not a lot off people actually cut the spark plugs. I have wasted 2 plugs already tried cutting with a hand saw that didn't work. Tried it with a sawsall cut around it and wiggled the threads with pliers broke the white part, tried again with a grinder on a new plug broke the white part again. Any tips what's the best way to get the threads of without braking the white part? Now I only have 4 new plugs left
    Slidell, LA
    4,738
    Have a dremel?
    Jan 2013
    Cleveland, tx
    218
    No I don't need to get one them plugs are harder than I thought. Do you cut the threads or on top of the nut? From looking without cutting the plug it looks lean. How can a stock bike with stock jets at 100ft above sea level be lean? I need to cut the plug without f ing it up so I know for sure.
    Surprise, AZ
    2,428
    I use a lathe.
    Sounds like a air leak is causing the lean condition.
    Can you post pic of the spark plug?
    Jan 2013
    Cleveland, tx
    218
    I don't even have a dremel so no lathe as well lol. Already did a pressure test and also spread half a can of carb cleaner around everywhere after I changed the reeds I didn't take a pic of the plug before I destroyed it.
    Slidell, LA
    4,738
    Cut the threads at the base of the nut. Can you post a pic of the plug?
    Jan 2013
    Cleveland, tx
    218
    Way to leanClick image for larger version.
ID:	230533 stock everything pressure tested Click image for larger version.
ID:	230535 rebuilt carb. Warmed it up changed plug wot for about 1/4 mile killed it pulled clutch. What is the problem?? Stock bike stock jets EL 75 ft
    Aug 2014
    South Louisiana
    1,915
    What model machine? Stock as in bone stock?? No pipe, filter, eBay carb?
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Jan 2013
    Cleveland, tx
    218
    84 250r original stock carb and pipe Moose carb rebuild kit and filter.
    Aug 2014
    South Louisiana
    1,915
    Did you use the jets from the moose kit or use the original jets? Sometimes the kit are generic and don't meet oem specs. If you used the jet from the kit, switch them back to the original if possible. How does the trike run in general? What does the old plug look like from it warming up and riding around. When jetting my bikes and trikes I like to go for about a 3-5 mile ride trying not to idle too much if possible. Get back, kill it fast, check the plug. Just to make sure that I'm good across the board before I start checking individual circuits. Feel the performance, then look for it.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Jan 2013
    Cleveland, tx
    218
    I put the new jets in from the kit the original jets are plugged up all the numbers were the same.
    The old plug looks black but it's really old
    Slidell, LA
    4,738
    So WOT plug chop is showing you main jet only. stock main jet? You are using aftermarket reeds right? What size is your new main jet? New filter? Airbox lid on?
    Jan 2013
    Cleveland, tx
    218
    130 stock main from rebuild kit New moose filter air box lids on. O ya I have the power reeds the directions said they would make it run rich?
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by averysdad View Post
    Not a big fan of aftermarket jets. Moose jets are not the same because they have the same number. Order a 132,135,138, and a 140. You should be able to find a reputable bike shop near you with some jets. Surely in Houston.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Slidell, LA
    4,738
    No, you have to jet richer for the reeds, they don't make it richer. I would go up 1 on the main and drop your needle clip 1, pilot should be fine where it is.
