Thread: 200es carb question
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    200es carb question
    Got new plugs for my 200es, it fired right up when given throttle. It's fouling plugs and I was wondering if the air/fuel mix screw controlled the fuel or if it controlled the air? It's the stock carb.
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Scootertrash's Avatar
    In the sticks
    4,638
    If the screw is on the filter end of the carb it controls air, on the engine side it controls fuel.
    May 2015
    1,081
    So it's on the engine side, to make leaner I need to tighten it?
    Oct 2008
    NB, Canada
    852
    Yes, turning the screw in will make in leaner. My guess is that it really won't help with fouling plugs, pilot screw only really makes a difference at idle. Make sure your air filter is relatively clean. Also, carb slide needles and such do wear over time, so you may have to drop that a notch or two.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Mar 2007
    Texas
    5,045
    you have a carb that probably needs a complete rebuild. kits are around $22 shipped off ebay. make sure you get the kit with the pre-formed gasket. it will make live easier if the bowl gasket is already shaped. you will need a can of carb cleaner and lots of paper towels. you will want to ensure every crevis, orifice and hole is clean on the housing before installing the new kit once you remove the old one.
    ________________
    https://www.mikesatvfix.com
    ericmreimer's Avatar
    ericmreimer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Splendora, TX
    296
    https://m.youtube.com/watch?v=3k6T5riJpCA
    Here's a great post on this carb. This is actually part 2.5 where he covers adjustment. If you want the whole rebuild series, search is other videos on YouTube, he covers the whole thing.
    1984 Honda ATC200ES saved
    Project in progress 1984 ATC200ES with Trx200 rear suspension/200m front suspension
