Thread: electrolytic rust removal anyone?
    Apr 2016
    san diego
    18
    I'm debating making a electrolytic de rust tub .. wondering if anyone on here has anything good or bad to say about them. I currently use my sandblaster .. mineral spirits .. vinegar ...and other parts solutions . sometimes mix... thanks I'd appreciate any help
    May 2009
    S.E. Michigan
    1,251
    I've tried it. What I found is that you need a good amount of surface area on the anode, otherwise the system will quickly slow down as the rust and other crud accumulates on the anode.
    I was using re-bar on some parts and a nice 12V power supply, and at first the part to be cleaned really fizzed (meaning it's working). I found I had to check on the part hourly in order to clean off the re-bar to keep good cleaning action.
    Also, this won't magically remove the rust and reveal nice clean shiny metal. My experience is that is gets rid of the active outer layers and leaves behind a dark but solid layer of metal. It is great if you plan to topcoat it, but it doesn't get things clean like sandblasting does.
    It is a neat concept, but for me sand/bead blasting seems to be quicker and more effective.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    devore,ca
    1,055
    It works, but takes a while. Use multiple Anodes. The "washing soda" was hard to get here in California so I tried some different solutions with bad results. Getting the washing soda was key for me.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Apr 2016
    san diego
    18
    thanks guys I appreciate the advice . I'm gonna look into it for a bit. kinda sounds about the same as a solution bath. I was planning on rebar for the anodes . they have washing soda at walmart by my house in here in sd. maybe a. more conductive anode set up widea than rebar.
    Apr 2016
    SE, Michigan
    3
    I've had great success using an old brake rotor for the anode. plenty of surface area.
