Results 1 to 9 of 9
Thread: found a 200s for sale cheap. 200S forks fit a 200es
    ericmreimer's Avatar
    ericmreimer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Splendora, TX
    296
    Does anyone know if the forks from a 200S (looks like maybe a 83) would fit a 200es?
    Thinking about picking up a 200s could use the forks, looks like a decent tank too.
    Different subject and project.....I'm also thinking about grabbing a 200x. I could maybe use the 200S as a donor for a auto X project in the future.
    1984 Honda ATC200ES saved
    Project in progress 1984 ATC200ES with Trx200 rear suspension/200m front suspension
    Tionesta, PA
    5,747
    Nope - 200S forks are much different that 200ES. They will not fit.
    Jul 2013
    Splendora, TX
    296
    Tionesta.....I have family in Pleasantville. Actually, I'll be driving from Texas up there in July and will probably go hiking in Tionesta with the kids.
    So whats different? Is it the head tube size? I'm looking to get away from the factory front end to a rebuild-able front end. I see a lot of people doing 200m swaps but 200m's are hard to find other than e-bay. This 200S is $100.
    Tionesta, PA
    5,747
    200M is the only one that works. The stem is pretty long on the ES.
    Jul 2013
    Splendora, TX
    296
    Great, thanks for the heads up!
    Oct 2008
    NB, Canada
    852
    A complete 200s front end will directly bolt onto a 200es, but a 200s uses a 22x11x8 tire, while the 200es uses a 25x12x9. A 200m or '83 ATC200 (no letter) is the best swap as they both use a 25" tire and 9" rim.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Tionesta, PA
    5,747
    Gearheadtom - are you 100% positive that the steering stem is not longer on the 200ES. I think it is like 1.5 inches longer.
    Oct 2008
    NB, Canada
    852
    I'm about 99% sure that all the 185 and 200 (excluding all 200x models) basically have the same steering neck, and the front ends will swap between them all. I've got a 200m front end on my 200es right now, and had a 200m front end on my 185s when I first bought it, everything bolted on.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    For what it is worth, I know that the stem is at least an inch longer on my 200es than the stem on my 250es. Kind of backward logic, but who am I to second guess the HMC engineers?
