Nope, you've got me beat there. Obviously you were diagnosed long ago. Interesting how your criticisms of others always included the same behavior you're criticizing.
Im pretty easy going. Laid back is more like me when it comes to pricks like OldSkool. But don't get me wrong. Ill only take so much sh!t though...
I don't remember him driving an hour to get it, i don't remember him talking to the owner about it, I don't remember him getting handed the title for it, I don't remember him loading it on the truck, I don't remember him driving back, i don't remember him unloading it, i don't remember him pushing it into the shop... i think everyone gets my point. I have alot of sh!t happening in my life right now. And NO its not teenage drama. Its not even close to that... I could go on about whats been happening but i come here to forget about it for as long as as i can. And im pretty sure no one would care or want to read/hear about it as they have THEIR OWNgoing on. I bought the bike for a reason (thats that sorry if your pissed about it). I was actually expecting something tore to shît and just all round pile when i looked at the add on CL. And who knows maybe it needs completly rebuilt if the PO was running lean.
Sent from my SM-G935V using Tapatalk
Saying "it's the trikes fault" is like saying "guns kill people"
don't poke the bear... you'll get banned
anyone use these painted chains? Im wonderin if it would be worth it buying these because of the paint they have
Kid, you could still pull the switch apart and clean the oxidation off of the brass contacts with some scotchbrite or steel wool. Pretty easy job, I've done it on a couple machines. You could clean up the headlight switch as well then.![]()
Don't run those cheap arse colored chains!! Get a DID at the least!
Years ago I warned a buddy about them.
He adjusted it at my house, hit the track and an hour later it stretched so much it fell off and screwed his case all to hell.....
What DC said ^
DID is the way to go.
The Volar chains are not that bad, they are o ring and they last awhile. I have one on my Xr 200. I have had it for about three years now and only had to adjust the chain once.
1979 Atc 110 helm and son
1977 Atc 90
1980 Atc 110
1984 Atc 110
1985 Atc 110
1988 XR 200 bored 40 over,
Atc 200x bottom end.
Alright ill look up "DID"
I've got about 5 hours on one of those chains and its still good no adjustment needed. But I don't plan on keeping it. I'll get a DID and keep this as a back up.
85 Tri-z Basket Case
I found 2 holes in the head pipe. Would that be the cause of the excessive popping? The spark plug is dark colored so it's not running lean
Yes. It will. It will suck cold are in and could very well crack your exhaust valves.
Do a compression test. If the compression is good the. Weld the holes.
One of the best chains ever made is a protaper chain. They cost good $ but will last many years w/o issues or breaking.
________________
https://www.mikesatvfix.com
