Page 15 of 20 FirstFirst ... 5 13 14 15 16 17 ... LastLast
Results 211 to 225 of 291
Thread: 200x
  1. #211
    1979atc's Avatar
    1979atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2015
    NW Ohio
    213
    Yeah the pipe won't affect it from starting. I assume the carb got something in it. But if you are running stock jets with aftermarket pipe you need to jet your carb.
    1979 Atc 110 helm and son
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    1988 XR 200 bored 40 over,
    Atc 200x bottom end.
  2. #212
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Quote Originally Posted by 1979atc View Post
    Any idea what jets I should use? It runs lean
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
  3. #213
    YamaBoss's Avatar
    YamaBoss is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2014
    Minnesota
    251
    Quote Originally Posted by AK47KID View Post
    Try one or two jets bigger then stock. No one can tell you exactly what to use, Every bike is different.
  4. #214
    May 2015
    1,081
    Quote Originally Posted by YamaBoss View Post
    Main, pilot or both?. I'm still a Virgin to jetting
  5. #215
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    I'm not saying it would work, it should at least still run half ass with a different pipe. I would say like a 42 pilot and 125 or so main. Clean the carb and stuff, heck probably get a new carb off eBay for $25. The gas these days is complete if you ask me, we have a shop here in Ohio and usually he have to get new carbs for customers bikes and stuff. Sometimes it's best to do that when our Sonic tank don't do the job, which is pretty rare.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  6. #216
    May 2015
    1,081
    So what model is the carb? Mikini?
  7. #217
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    It's should be kehin carb, but ones made by China are good replacements. A honda carb which is a kehin for a 200x will run around $80 to $100. Which isn't worth it unless you are making the bike museum quality, and to have everything original.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  8. #218
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Does your carb have the nut on the bottom of carb bowl or just the over flow tube?
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  9. #219
    May 2015
    1,081
    It has both the nut and over flow tube
  10. #220
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Here ya go, this is the carb you need.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  11. #221
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    I know it says 87/86 on the listing, but in the description it is the 1983/1987 they are the same carbs. I'm getting this exact carb for my XR.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  12. #222
    May 2015
    1,081
    Instead of running a 125 main I think I'm gunna buy 112, 118, 120 main and buy 42 and 45 pilots. Play with those and see. I read on a different forum that someone was running a dg pipe with 112. Main. What's y'all's opinion on that?
  13. #223
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Sounds about right, that's all you can do at this point is play with jets and see what it does. It should still run with the pipe but it won't run crisp.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  14. #224
    May 2015
    1,081
    You just said it won`t start .......you don`t know jack about if it`s lean or rich ! What is the starting procedure ?
    When I do get it to start the plug is lean
  15. #225
    May 2015
    1,081
    Never the less I need to clean my jets. They are clogged. That's the main reason why it won't.
