Page 2 of 20 FirstFirst 1 2 3 4 12 ... LastLast
Results 16 to 30 of 291
Thread: 200x
    Oct 2013
    Wherever I May Roam
    3,757
    The air valves are for adding very small amounts of air to tune the ride or used as air bleeds. Personally I only ever use them for bleeding off air that builds up. Never use a compressor to add air unless it is regulated to about 10 psi. A bicycle pump is a safer option. If they dont have caps on them, install some.
    Mackus84's Avatar
    Mackus84 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2016
    Lakeland, Fl
    427
    ^^^^ what he said. I used a bicycle pump and gave it a tiny little push and it stiffened them up considerably. It doesnt take much. Im a bigger guy so i wanted them with a little less give
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    It has the original caps
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Oct 2013
    Wherever I May Roam
    3,757
    Quote Originally Posted by AK47KID View Post
    I noticed after mentioning. That bike has been ridden AND taken very well care of. Very very rare to find a 200x that complete. Not to mention you stole it at 700. I am jealous.
    May 2015
    1,081
    Hold your horses for now, who knows if it needs engine work. I'm going to start cleaning the carb tonight.
    Oct 2013
    Wherever I May Roam
    3,757
    Exactly how many days does it take you to clean a carb?
    Taking it apart already, oh boy!
    Yeah I don't mind a little engine work. I learned everything I know on the internet!!
    Slow and steady.
    Jan 2015
    Haskell, TX
    53
    First thing id do is get maier plastics and store the originals. I'd also probably redo a not so nice seat and store the original seat too.
    Or, since it looks like a GREAT candidate, restore it and never ride it.
    I wouldn't even think about containing myself. I'd have a dent in the tank and the plastics cracked within a week! Probably my tail bone also.
    Present trikes:
    85 250es
    83 ATC 110
    Past:
    85 200X
    Trimoto 175
    May 2015
    1,081
    Slow and steady.
    All I do is spray some kind of cleaning solvent and use and air compressor. Spray them down wait an hour or so and spray compressed air through them.
    Jan 2014
    La
    1,062
    It does look great I would clean and polish everything and ride it not hard mind you its to nice to abuse.
    Sent from my KFFOWI using Tapatalk
    May 2015
    1,081
    Whoo hoo, got it to start. Revved it up and OMG it sounds mean like a 450. Apparently it's not a bassani
    Carb clean well acceptably clean
    Oct 2013
    Wherever I May Roam
    3,757
    That carb is NOT NOT NOT acceptably clean.
    Great news though. Glad it started.
    The coffmans pipes are rare.
    Don't forget to change your oil.
    Manheim, PA
    5,817
    That is not a clean carb....thats a half assed attempted at a kid cleaning a carb not knowing WTF he is doing.
    Soak the carb in pinesolve for 30 mins to an 3 hours. It will eat everything off it and it will cost you $5. I do this with all my carbs...much longer it will eat the metal. Do no soak your slide or anything made from carbon steal. It will rust it with in about 5 mins.
    Rinse off in hot water with dish soap, let dry and install few hours or next day later. You will want a new carb seal also. That one is just too old anymore and if you pull it out it will not seal correctly again.
    Soak the brass jets and aluminum only, nothing else. Rest just use carb clearner and compressed air. Also once its back together never let it sit with gas in in the bowls. Drain it out and always run fuel cleaner in every tank. Gas goes bad after 2 weeks now days. Installed a fuel filter also...I sell them down to 150 microns. Use clear fuel lines and you should be golden.
    Follow my directions and you will be fine. Do not follow them and well then I give no meows what happens.
    http://www.ebay.com/itm/401080867868...84.m1555.l2649
    http://www.ebay.com/itm/121942441009...84.m1555.l2649
    Trust me...been doing this for 26 years.......
    May 2015
    1,081
    Follow my directions and you will be fine. Do not follow them and well then I give no F*cks what happens.
    The bowl is the only part that looks like that. Everything else I used compressed air and carb cleaner and a paperclip.i can see through the other sides of the Jets when I look through them. Where can I get pinesolve? My Walmart doesn't Have it (Imagine that)
    Oct 2013
    Wherever I May Roam
    3,757
    Pine Sol.
    That dirty bowl will cause problems eventually. Git er clean.
  15. #30
    Scootertrash's Avatar
    In the sticks
    4,638
    Pine-sol maybe?
    knowbuddy prufe reeds there posts nowadayz. Reeleyeing on ottocorrekt to speel everthing for them.
    ETA: Beet buy a minnet
