Page 6 of 20 FirstFirst ... 4 5 6 7 8 16 ... LastLast
Results 76 to 90 of 291
Thread: 200x
  1. #76
    plevib's Avatar
    plevib is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2015
    North Dakota, USA
    358
    I've got a nice pretty switch for you
    Pm me if you're interested
  2. #77
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Quote Originally Posted by plevib View Post
    Tempting...let me look and see if I can't repair it first
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
  3. #78
    May 2015
    1,081
    Okay, I've bled the lines of air. But I'm not getting any pressure.
  4. #79
    Mackus84's Avatar
    Mackus84 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2016
    Lakeland, Fl
    427
    Ill go out on a limb and say the piston on the caliper is frozen. You said it was stuck with the front brake grabbing. So the piston was all the way extended. In the elements, dirt water all that good stuff. Its gonna have to come apart
  5. #80
    May 2015
    1,081
    Quote Originally Posted by Mackus84 View Post
    I don't think it's frozen. With out the bleed nipped in the brake caliper I push the brake handle and the oil comes out. When I put the bleed nipple back in the caliper with out the rubber cap oil won't come out. I'm definitely doing something wrong. I've never felt with hydraulic brakes
  6. #81
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    Pump brakes, hold, open bleeder. Close bleeder. Release lever. And make sure u dont run out of fluid while doing it. Keep the lid off the master and keep the level up. And only the right brake fluid. Manual says dot 4 i think. I used dot 3. No issues
  7. #82
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    And u dont take the bleeder all the way out when u do it. Just crack it, then snug it up
  8. #83
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    With mine, i took the caliper off the bracket, and held it in the air like head level and it pumped it. That helped push the air out more than anything i did. Oh and btw, if your caliper piston in frozen, then it will still bleed it out, but the piston will not move in the caliper, and it will not squeeze the pads on the rotor
  9. #84
    May 2015
    1,081
    The front and rear calips are shitttyshottedjunkedoutthedoorgonerustedtoshiot. Looks like I'm in the market for new ones are there any new calips I can use from this century on the 200x? Or am I screwed to get used 200x calipers?
  10. #85
    May 2015
    1,081
    The front one is rusted so bad heat and wd40 couldn't break it loose
  11. #86
    May 2015
    1,081
    Any one have a set that don't need rebuilt. Maybe I can trade you my pair that need rebuilt for a pair you have that don't need rebuilt and I can pay like $20-30 to even out the trade?
  12. #87
    Scootertrash's Avatar
    In the sticks
    4,638
    Quote Originally Posted by AK47KID View Post
    Tried the search function yet?
  13. #88
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    Pretty much any mid 80's to like 2003 Honda Cr80 FRONT caliper works on the REAR. I am using a 1995. And I am using a 1998 Kawasaki KX80 REAR caliper on the FRONT. Im sure other years will work. This is a direct bolt on swap. The only thing you need to do is use the original 200X brackets for both calipers and they mount up with no modifications.
    Heres the Cr80 front on the back of the 200X Click image for larger version.
    And the KX rear on the FRONT Click image for larger version.
    I got complete brake setups on ebay, master cylinders, calipers and all for front and back for less than $50. They are plentiful. You will lose your parking brake though as the Cr80 obviosly doesnt have one.
  14. #89
    Mackus84's Avatar
    Feb 2016
    Lakeland, Fl
    427
    Haha i was gonna be a smartass and say the same thing, but figured I'd take the 45 seconds and help the kid out. Hey kid, like he said^^^^. Have you tried the google search function.? Theres at least 5 or more threads on this site about brake caliper swaps, just google it and they pop up
  15. #90
    Willamstown PA
    5,824
    Rebuilding calipers is easy. Air compressor 10mm bolt in the banjo hole. WD40 entire thing let sit 24 hours, drain out and blaster bleeder hole with 100PSI from air compressor.....pop goes the piston. You need $15 rebuild kit, and $10 for new pads...good for another 20 years. You can even buy new pistons and most times they are fine. Just get stuck from sitting so long.
    Not hard to do. I've rebuild stuff people said you can't...why because being stubborn and stupid is the easiest way to spend extra money you don't need to.
    Wanna know something else...I am not cool, I know nothing related to 200x's. I'm a 5ft 6" southern asshole from Virginia who almost went to jail. Go chew on that all mighty know it all, next time people offer advise it's for the greater good.
    remember...we are the youth of the nation.
    age 32 and give no f*cks...........
