Thread: regulator/rectifier
    Jun 2015
    South Wales Britain
    18
    regulator/rectifier
    quick question would not having a regulator rectifier cause my 86 honda atc 125m to stop sparking
    Aug 2015
    Idaho
    842
    No. It's for charging the battery. Click image for larger version.
    Jun 2015
    South Wales Britain
    18
    many thanks any one know the best place to pick one up i'm in the UK
    Feb 2016
    Georgia
    66
    Amazon .com!
    Apr 2012
    USA
    4,133
    To diag the no spark issue, you'd want to test your ignition coil, alternator/generator, pulse generator, and if all test good, then possible CDI replacement. Everything is tested with a multi meter, specs are in the service manual, if you can't find it post and I'll screen shot the specs.
