Results 16 to 30 of 31
Thread: 200x Help!
    Jul 2013
    USA
    737
    I havent followed these 200x threads latley so to me it sounds like a dirt in the carb with the backfire situation. Not sure what else causes backfiring on deceleration. A compression check may save you time. Did it ever run right for you? Hope you get it going.
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    Quote Originally Posted by fieldy View Post
    Sounds silly but a broken/weak choke valve spring did this to me for a bit on my 110, it looks open when sitting but will suck itself shut and run rich until you let off the gas. I was at wits end with it until I read the same advice on this site somewhere. Use a pull tie to lock the arm open and see if that helps.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Oct 2015
    Texas
    35
    It back fires during the cruising not deceleration. Choke is open, carb is clean. The only time it ran better is filter less.
    Oct 2015
    Texas
    35
    200x Help!
    I'm near Dallas! McKinney actually!
    It's going to be something out of the norm, I'm very mechanically inclined and have tried all the normal ideas. I didn't come to y'all before, I've tried almost everything already.
    Slidell, LA
    4,738
    how old is that sparkplug?
    Only two reasons for your backfiring on acceleration.
    1. Air to fuel mixture incorrect
    2. Electrical issues (timing and/or not enough spark)
    Backfire on deceleration, that's a different story.
    Oct 2015
    Texas
    35
    Not back firing on acceleration either, only constant throttle, cruise control! I'll change the needle then adjust my air/fuel mixture again, but with the exhaust and air box, something is bad or out of place. Hoping the needle or seat is bad, that way I know it was something beside normal tuning. Spark plug has 10-15 mins riding time
    Oct 2015
    Texas
    35
    I'll check timing, I also think that may be a cause!
    Slidell, LA
    4,738
    Quote Originally Posted by jkg2003 View Post
    uh, constant throttle is acceleration....you have to keep momentum somehow.
    Mar 2007
    Texas
    5,045
    Your dumping fuel into the engine. Are you sure the jet is correct? I know I have resized jets track side for my son's racing quad and made noted on the box. Try getting s known sided jet and put that in there. Also is the choke working properly. If choke is letting extra fuel by it will also cause this.
    Only other thing,
    Are you blowing smoke when it runs? If you are it could be some oil too.
    ________________
    https://www.mikesatvfix.com
    Jan 2014
    Massachusetts USA
    782
    What about float level, has it been checked? Put a piece of clear tubing on the bowl drain nipple, route it upwards, and open the bowl drain screw. The fuel should come up in the tube, and end up about level or a little bit lower than the float bowl flange.
    1985 Tri-Z 250
    1985 ATC250R
    loganm is offline Competing with a gnat in reading comprehension. Current winner: Gnat. Arm chair racerAt the back of the pack
    Jun 2015
    Kansas
    364
    If it's rich have you tried just going down in main jet size? Do the obvious things first and note what happens before you get into any nut job theories.
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    I understand, but there isn't a spark issue, exhaust not the issue. The filter is oiled, will put a new moose filter on it tomorrow with the needle.
    The moose filters are great. They will also help to keep elk out of your engine.
    Oct 2015
    Texas
    35
    200x Help!
    I am at a 102 main jet, tried that first, float level hasn't been checked, is there a way to adjust the plastic floats, only reason I didn't check it. No considerable smoke, only a slight puff at start up.
    Mar 2007
    Texas
    5,045
    No adjusting plastic floats. The needle may be bad.
    ________________
  15. #30
    Oct 2015
    Texas
    35
    Quote Originally Posted by tripledog View Post
    I heard they will keep caribou out as well!
