Results 1 to 15 of 15
Thread: 85 200X UNI Air Filter Fitting
    Aug 2015
    Swisher, IA
    92
    I recently purchased a new UNI air filter for my 85 200X to replace my stock air filter which had ripped. The UNI air filter mounts into the air box and is held on only by a hose clamp unlike the stock air filter which has the bracket to hold it on. The problem I am having is that it is sometimes difficult to keep the air filter on. When I tighten the hose clamp too much around the rubber part of the air filter, the air filter will just slide off. When I tighten it to where it will stay on without sliding off it is not on tight enough to stay on through rough riding. Is there a quick fix to this or anything I can rig up for it to stay on tight? The bracket from the stock air filter will not work with this air filter.
    "You see, in this world there's two kinds of people, my friend. Those with loaded guns and those who dig. You dig."
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    1983 Yamaha Tri-Moto 200
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    Mine did the same, make sure the part that touches the mounting bracket (Inside lip) of the filter is oil free (Clean with rubbing alcohol) and the lip of the mounting lip on the air box is oil free (Also clean with alcohol) then try again, it will grab a lot better, just make it snug, do not over tighten.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Aug 2015
    Swisher, IA
    92
    I made sure I cleaned off the filter oil but it still seemed to slide off when I tightened it. It stays on when I am riding around on flat ground, I just don't want to risk having it pop off when I'm out riding in the woods. Just looking for a way to mount it so I know that it will stay on for sure when I am riding on rough ground.
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    Jun 2006
    Omaha Nebraska
    321
    Put a ring of thin two-sided tape on the flange before tightening, it will add friction or you could poke a hole in the uni and use the factory cross bracket.
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    If you dont care for the air box you can always do a direct filter on the carb. I think you have to buy a filter with a smaller rubber mount
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Slidell, LA
    4,738
    Quote Originally Posted by apickering975 View Post
    You need some airbox rings made. They slip into the grooves of the airbox so you can clamp the filter on tighter. PM Dirtcrasher. He was making them at one point. Maybe he will make you a set. His forum post concerning the rings is below.
    http://www.3wheelerworld.com/showthr...=air+box+rings
    Aug 2015
    Swisher, IA
    92
    I wanted to use the stock bracket to hold on the UNI filter but the screen inside of the stock air filter does not fit inside of the UNI filter. Instead of a screen the UNI filter has a spring like stabilizer inside leaving nothing to screw the bracket into. Has anyone found a way to mount the bracket onto one of these filters?
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    Aug 2015
    Swisher, IA
    92
    I will look into those air box rings. They look like they will work good and be reliable when riding on rough terrain.
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    May 2015
    1,081
    Thats weird... mine i clamp on as tight as i want and it doesnt slip off
    Aug 2015
    Swisher, IA
    92
    Quote Originally Posted by AK47KID View Post
    On a 200X?
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    May 2015
    1,081
    On a 200X?
    Ya
    Slidell, LA
    4,738
    On a 200X?
    I never had issues with my 200x either. I ran a UNI with an outerwear and it was tight as can be. My 250R was a completely different story.
    It just depends on the condition of the plastic in the airbox (if its still rigid or if it has become malleable over the years)
    Aug 2015
    Swisher, IA
    92
    Makes sense. Im still waiting on a reply from dirtcrasher but Im definetely going to order one when I get ahold of him.
    Trikes Owned:
    1986 Honda 250r
    1985 Honda 200x
    1985 Honda 200m
    1984 Honda 200es
    1983 Honda 200x
    May 2018
    Winnipeg
    Having the same issue with my 84 200x, I'm a little late to the thread though lol.
    N.E. Ohio
    2,002
    I like my Ring made by member here, it plane works. It’s a trick little item that solves a 20yr+ air box issue from maintenance by former owners and worn plastic/rubber.
