Results 16 to 30 of 74
Thread: Flat track
    Jul 2013
    USA
    737
    Do you guys like wider handlebars bars for ft. The KXT i own looks like it was raced and it has 35" bars like they came off a kx but they are bent. I want start looking for some better ones. Origional KXT bar width is around 31.5".
    Jul 2012
    Joplin, MO
    597
    I think most of the guys I race with like them a little wider. I am running some steel bars that I got somewhere that are wider and a low bend.
    Jul 2013
    USA
    737
    Anyone from central Indiana or Ohio racing? I need some inspiration and friends to talk with. Not much three wheeler stuff going on in this neck of the woods.
    Buffalo, NY
    1,994
    There were some good races in Ohio this year, 2 at Pine Lake in Ashtabula and 1 at Western Reserve
    efhondakid's Avatar
    efhondakid is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2015
    Canton Ohio
    203
    I run 18x8 mower tires at 6-8psi. A durablue +4 axle with durablue +1 hubs wheels are 3x5 that is maximum width. I run that for TT, regular FT I use stock hubs inside wheel flipped around and a +3 spacer on the outside.
    You’ll want a lowering link for sure, just strapping the axle makes cornering feel like you are a rock skipping across a pond. I run Protaper ATV Mids and roll them way back so they are in my lap when I’m in the pocket.
    2 in the back, 1 in the front.
    N.E. Ohio
    2,005
    Quote Originally Posted by efhondakid View Post
    lol that's a great discription Quote of the day.
    Jul 2013
    USA
    737
    @ 86 T3- I went to Ashtabula in 2016 i believe it was, got the T-shirt. Went through the pits and may have seen the 500 kxt you were riding. If i am right, maybe not. Stuff i seen from this forum. There was also a 4 stroke kxf or something like that running some real small wheels. That one seemed like it wanted to spin out quite a bit in the turns.
    There was a big dude on a Honda that was sliding around that track about the whole time. Number 51 or something.
    It was very enjoyable but dang was it a hot weekend. Those guys on the starting line looked like they'd been microwaved.
    The Open Road
    4,736
    .....You’ll want a lowering link for sure,.....
    Where does one find lowering links for an 86R?
    I
    Slidell, LA
    4,738
    Durablue had them the last time I checked, but that was 3 or 4 years ago
    6,810
    I just installed one a few months ago , very nice quality .
    I
    Attached Thumbnails Attached Thumbnails 009B0A5D-A676-40FE-B03C-8731E7823CE5.jpg
    Jul 2013
    USA
    737
    I think i remember reading that you did pretty well in a race. I have some type of a "lowering link" i bought "for"a 86 Tecate. Haven't studied it. Looks like it just replaces the shock.
    I will be rebuilding my shocks and forks this winter. Might have to talk to race tech or something. I want one spring and factory shock for flat track with small jumps and another regular factory shock. Maybe you guys would suggest a flat track shock guy and simplify my chores.
    efhondakid's Avatar
    Feb 2015
    Canton Ohio
    203
    A nice rebuild is all you really need. There is no real need to go all out with changing valving and everything. The stock rear shock is decent, new seals all around and some progressive springs in the front will be just fine. I race everything on my R, hare scramble, MX, FT/TT and the only changes I really ever make is ride height.
    The Tecate link is a completely different setup than the R and will not work.
    Carthage NY 250r rules
    2,355
    I
    You may have to order one for the trx 250r.
    250r rules
    Jul 2013
    USA
    737
    Here is the one i got. No shock at all sounds worst than just skipping over water right? I may find out that it replaces the dogbone, dont know yet.
    Some people must have used them to race. The shocks are about 4" longer than the link.
    I agree a real expensive shock isn't the way to go.
    I should start calling around for the right fork springs. I got books, gonna try them all myself.
  15. #30
    Jul 2013
    USA
    737
    I
    Buy one? You could whittle one of those up with your eyes closed.
