Thread: R long rod with spacer plate: What base stud d I need?!
    May 2005
    Southern NH
    1,489
    Question R long rod with spacer plate: What base stud d I need?!
    Hey guys,
    Running into a little trouble here. I was rebuilding the engine and upon taking it apart I noticed the main bearings had a little play on the crank so I decided I mine as well update to the long rod if I have to buy a new crank anyway. I have an OEM cylinder with an LA sleeve and the spacer plate from them as well.
    On the 85-86 ATC250R parts fiche it lists both 10x70mm AND 10x45mm. Upon pulling mine out I measured and they are a 10x70, all four. So I am thinking I need a 10x80mm at least?
    Also, what did you use for a dowel that goes between the case, spacer and cylinder?
    Thanks in advance guys!
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
    Jul 2012
    Joplin, MO
    597
    Eddie Sanders Racing has what you need.
    http://www.eddie-sanders-racing.com/category_s/133.htm
    May 2005
    Southern NH
    1,489
    Quote Originally Posted by The_Steve_Man View Post
    I went to them as one of my first options, but what worries me is that they do not say the length of the Cylinder Long Stud. I don't know how ESR cylinders compare to stock? Maybe they have a taller stud channel on their jugs than OEM, in which case there wouldn't be enough thread on the stud. I'm just thinking out loud, but have you purchased these before?
    Jul 2012
    Joplin, MO
    597
    I have not. I don't know what length they are. You could use threaded rod or bolts. The dowels will line the cylinder up.
    Jun 2003
    englishtown NJ
    2,676
    you need the longer dowel to line the cylinder up correctly. Just buy the esr kit, I use that for my lrd/led pro-x cylinders and stock ones in the past.
