I don't know how much the compression release is going to cost. I spent $30 on the valve itself and sent it along with the head but I'm thinking Millar usually supplies his own valves. I bought mine ahead of time because I didn't know Millar was going to be doing the work initially. Initially I was just going to drill a hole through the head and send the valve through, done. Once I saw what MRE does, I decided to send my head to him. I'll post pictures. He's in Canada so it already cost me almost $50 in shipping alone, and he'll have it next week. I really like the idea of the small hole in the combustion chamber itself as opposed to the huge disruption the valve itself could potentially be if I had just fired it through the way I was planning. I do not want to give this engine any more reasons to pre-ignite.
I also ordered a used second gen R pipe last night because I really liked the idea of using that rather than the franken-pipe I've created. I think you're on to something there HondaRidr.
As far as the kick starter goes, I welded two bases together to get the proper clearance for the kicker to swing past the frame. You could do the same with that one I would imagine.
