Thread: Taillight bulb
    ArizonaATC is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2012
    Eastern Canada
    163
    Taillight bulb
    this is gonna be a stupid question but im getting annoyed with the taillight on my trike, i took the lens off and now i can get the damn light bulb out, it will not unscrew or anything its in there solid, am i missing anything?
    Nov 2015
    Manitoba Canada
    117
    Push the bulb in and turn it.
    1983 ATC 185s 200 jug bored .20 9.5:1 Naumura piston. Fast as ass when its not stretching the drive chain or stripping hubs.
    1986 ATC 250ES. *Total garbage trying to sell it*
    1983 YTM 200E. Runs good, forks are super bent but aside from that its mint.
    1984 YTM 200L. Barn find, everything is mint except the bottom end is bad... *waiting on a new engine*
    Nov 2012
    Eastern Canada
    163
    Quote Originally Posted by 81ATC185S View Post
    thanks! i knew it was something simple and stupid like that! got the new bulb in which is a 7 watt and the old one was a 5 watt (thats the closest one they had) and the tail light still dont work, maybe some connections corroded you think?
    Mexico
    9,019
    That you got it out without smashing the bulb and digging it out with a pair of needle nose pliers is a good sign.
    You may have a broken wire, or just corrosion on the contacts. Suggest you find someone who can use a multi-meter rather than guess your way into a bigger mess.
    It sucks to get old
    Aug 2015
    Idaho
    842
    If there is much corrosion in the socket, the light bulb won't make contact. Maybe try carefully cleaning socket with a small round brush. I always smear dielectric grease in the sockets. And yes you need a multimeter.
    How many plumbers does it take to change a light bulb?
    Five------1 to hold the bulb & 4 to spin the ladder
    Nov 2012
    Eastern Canada
    163
    Quote Originally Posted by Jd110 View Post
    thanks haha il give that a try!
    why shouldnt you play a plumber in poker?
    a good flush beats a full house everytime.
