Results 1 to 9 of 9
Thread: Electrical issues
    ArizonaATC is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2012
    Eastern Canada
    163
    Electrical issues
    So today when i got done on my trike i gave it a good washing and especially all the mudd out of the engine area, but after i was done i tried starting it and no luck, so i check the spark because it wasnt even sounding like it was trying to start, the spark was very weak, no blue arc or nothing just a tiny weak one with no blue.
    also i dont know if this contributes to it but my battery use to charge up after 30 mins of riding and i could use the electrical start, for a few weeks though it hasnt been charging at all. Could this be a bad stator? what would you guys check first. thanks!
    Aug 2015
    Idaho
    842
    Ok. As you found out today-water and electrical systems don't get along. Try blowing things out now. And you need a battery tender.
    Nov 2012
    Eastern Canada
    163
    Quote Originally Posted by Jd110 View Post
    whats the best way to waterproof all the wires? i go through lots of swamp and water, wouldnt want it dieing on me way out in the sticks!
    Aug 2015
    Idaho
    842
    I wouldn't know because I stay out of the water for the most part. But I do run with dielectric grease on every connection.
    Don't forget to unhook battery before you start. Swamps in Arizona?
    Nov 2012
    Eastern Canada
    163
    im no longer in arizona! living in canada now
    Aug 2015
    Idaho
    842
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    JD110 has it right, dielectric grease in every connection will really help.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Nov 2012
    Eastern Canada
    163
    Quote Originally Posted by f76 View Post
    I have never used dielectric grease, learn something new everyday, i will pick some up tomorrow and apply it to all the conenctions, thanks guys
    f76's Avatar
    Jun 2014
    South Dakota
    323
    Fill the female side of the connector with a dab, you don't need to fill it full, it will all come out when the male plug goes in. Wipe off the excess.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
