Hey guys,
I'm working on an '86 Fourtrax 4x4 350 for a friend. I know it's a quad, but this essentially has a 350x mill in it.
I'll try to make this as brief as possible while including all the pertinent information.
Friend bought this after it had been sitting a few years. He asked me to clean and rebuild the carb. I took the carb all apart and was surpised at how clean it was inside after sitting awhile. I really didn't see why it wouldn't run right. Anyway, I soaked all of the parts in a disassembled state in Napa carb soak solution. This is the stuff that comes in a 1 gallon can and has the consistency of 10w-30 motor oil.
So the carb came out beautifully and I installed the brass from the Shindy carb kit he bought. I have always had reservations about aftermarket cab brass and always buy genuine Keihin for my own stuff.
I give him the carb back and he tells me it still isn't running right.
Now after he told me he had the cam chain tensioner out and rolled the engine over I immediately suspected the cam had jumped time.
So this time he brought me the whole quad so now I can see for myself how it runs.
First thing I did was check cam timing and found it to me correct.
So now I fire the thing up and it acts like the choke is still on, running very rough and emitting black smoke, especially from just off idle to about 1/4 throttle.
I verified the choke cable was working properly, even removed the choke plunger from the cable end and held it in place in the carb while running it and it still runs extremely rich down low. If I rev it up more it seems to run OK in mid-top throttle positions.
Now I gave him back the original carb brass and told him to hang on to it. I asked for the original brass back and will be getting it tomorrow. I'm hoping that swapping the OEM pilot jet back in will cure it. But if not I am wondering if the o-ring on the choke plunger is to blame??? Choke plunger looks very good, not pitted and doesn't seem to stick at all. Would a faulty choke plunger o-ring make it run very rich down low??
Also I should note that he replaced the fuel pump and I verified the fuel pump is not overpowering the float, needle, and seat by rigging up a gravity feed fuel tank. On gravity feed it runs the same.
This one is starting to have me scratching my head because it seems like it runs OK of you rev it past the terrible rich spot in the lower RPM range. I kind of find it hard to fathom that Shindy could have the pilot jet size so wrong, but anything is possible I suppose.
