hello guys so i hooked up my battery charger (2A) to my trike battery and it isnt charging, the light that says charged is only coming on, which it isnt because it wont even move the starter, whats my problem? thanks again guys!
i suppose! but wouldnt it still atleast try to recharge? the light that say charging on the charger isnt even coming on! and the battery would take a charge after 30 min of riding 2 weeks ago and it would hold enough of a charge to use the starter. if i do need a battery what would be the best bang for my buck for a good battery
"You see, in this world there's two kinds of people, my friend. Those with loaded guns and those who dig. You dig."
Trikes Owned:
1986 Honda 250r
1985 Honda 200x
1985 Honda 200m
1984 Honda 200es
1983 Honda 200x
1983 Yamaha Tri-Moto 200
update: its not saying its charging but it is a little, unhooked the charger and the headlight would come on dim and the starter buzzed but wasnt strong enough to rotate, this was after almost 1 hour so il leave it on for 6 or so and see what happens.
also jeez 3 wheeler world be loggin me out after 3 min of tardiness like its a bank website
Trikes Owned:
1986 Honda 250r
1985 Honda 200x
1985 Honda 200m
1984 Honda 200es
1983 Honda 200x
If you need to get a new one, get a sealed battery. I've had better luck with them compared to the conventional batteries that are vented. Also, unless you ride in the winter, remove it from the machine in the winter and keep it inside and on a battery buddy (or any other battery tender). It will last you a long time this way. Even if you can't remove it, keeping it topped off on a battery buddy while you don't ride it will keep the battery in great shape.
- Frank
1984 200ES Big Red
1985 350X (x2)
1986 350X
1986 250SX
1984 Auto-X
1984 ATC70
1985 ATC70
2 amp charger might be a bit much. Most motorcycle battery chargers are under 1 amp. A 2 amp would be more for a lawn tractor or a side x side. The small motorcycle batteries won't take much abuse at all.
YAMAHA 450 HYBRID
85 350X- RED
85 350x -BLACK
86 350x-WHITE (with Goki)
85 250r
83 atc 70
84 atc 70
84 atc 110
09 yfz 450
2006 Arctic Cat Prowler
RZR XP 900
you need a new battery. Plain and simple!
